How to convert 03-05 to 06+ R6r exhaust - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 578 (permalink) Old 08-10-2008, 02:22 PM Thread Starter
Focus
zac5876's Avatar
Bike: 06 R6
**First let me say, some of the pictures are courtesy of cafercr35 from sportbikes.net.**
1) First things first.
You need a muffler from a 06 and up R6r
2) Prepping the new muffler
You need to cut 2 and 7/8 inches off. The part with the exup/butterfly flap is what needs to come off. Start measuring from the lip.
Dispose of the exup/butterfly flap piece.
Next I cut off the hanger on the muffler as well. To me it wasn't a huge problem with it not being the cleanest cut, because it is hidden, and the cut will not be visible.
3) Prepping the bike
Now is, what I thought to be, the hardest part. You need unbolt the support for the exhaust pipe. (blue circle on the right)
Next you need to literally pry down the pipe that is on the bike down from its original position about an inch or so. The goal here is to set the hanger that is on the manifold on the bottom of the hanger that is on the bike; wedging it if you will....
Now there's a few ways of performing the next task...
***It's important to understand that the whole manifold is still very secure even with the removal of this hanger***
You can fabricate something to secure the pipe from moving back to its original position, like this. This is really the better thing to do.
Or what I did is I used the original bolt I took off that supported the pipe and put a huge washer on it and fastened the bolt right back on, with the pipe under it. The purpose being that it will not bump over and slide into the original position (if it did slip over, it would cause the new pipe to hit the swing arm). This worked just fine for me!
4) Fitting the new, prepped, muffler on the bike
The outer diameter of the muffler is 2 inches. The inner diameter of the stock exhaust is 2. It does fit. What some people will do is apply a relief cut at the end of the pipe (the pipe that is on the bike itself) for extra clamping power. However, the clamp I used (pictured below) allows for more than enough clamping power.
Now bolt everything back up!
F.A.Q.
Q- Is there a lack of support for the mufflers weight? (If you went the washer route)
A- No, it would probably take at least 50 pounds to move the thing.
Q- Does it rub on the swing arm?
A- I had about a half inch clearance, with full travel of swing arm.
Q- Does your foot hit the can?
A- I wear size 11, and the back of my shoe made contact maybe twice while the time I owned the bike.
Q- Will the heat from the new muffler damage my plastic (because it is closer)?
A- No. There is a black metal shield at the base of the new muffler. This piece will be the only part that will make contact with your plastic. It acts like a heat shield, it will not get hot enough to cause damage.
Sound clip
A better sound clip courtesy of endosj3
zac5876 is offline
post #2 of 578 (permalink) Old 08-10-2008, 03:30 PM
Bike: Ducati 848
Re: How to convert 03-05 to 06+ R6r exhaust
Nice!!!
J Buck is offline
post #3 of 578 (permalink) Old 08-10-2008, 08:23 PM
Bike: 05 R6
nice write up.. im bout to do this to my 05. could u take a picture of the clamp u used? and what is the HUGE washer exactly doing?
MODS:
flush turn signals
integrated tail light
IXIL undertail exhaust
Red devil eyes
pepox_dns is offline
post #4 of 578 (permalink) Old 08-14-2008, 10:47 AM
08 R6 SuperStreet
kleners's Avatar
Bike: 08 Yamaha R6
I posted my experience over on the Exhaust forums.
It was easy. The lower pipe bracket needed to be moved because without it, the exhaust would go right into the swingarm and peg.
And i used the same clamp that held the old pipe on.
Just for updates!! Your mid pipe, i would cut a small slit on one side to allow more clamping power to hold it on.
kleners is offline
post #5 of 578 (permalink) Old 08-22-2008, 04:16 PM
Bike: 2004 R6
Images: 1
THANK YOU!!! I wanted to do this really badly! How does it sound? I want something a bit louder than the stock exhaust. How much would someone sell one for?
clrumivier4life is offline
post #6 of 578 (permalink) Old 08-22-2008, 04:33 PM Thread Starter
Focus
zac5876's Avatar
Bike: 06 R6
zac5876 is offline
post #7 of 578 (permalink) Old 08-26-2008, 06:18 AM
Bike: 2004 R6
Images: 1
Alright, I've got an 08 exhaust coming on thursday and I'll put it on this weekend. I'll post some pics when its done. I'm so pumped!
post #8 of 578 (permalink) Old 08-30-2008, 12:40 PM
Bike: 2004 R6
Images: 1
I got the exhaust and put it on. Here's the pics. It sounds raspy and pretty loud and it looks great. Thanks for the write-up!
ID:	24519   Click image for larger version
ID:	24520   Click image for larger version
post #9 of 578 (permalink) Old 08-31-2008, 11:19 PM Thread Starter
Focus
zac5876's Avatar
Bike: 06 R6
That's awesome! Looks great
zac5876 is offline
post #10 of 578 (permalink) Old 09-10-2008, 09:24 PM
wstxr6's Avatar
Bike: '04 r6
Send a message via Yahoo to wstxr6
would it be the same if you were to put a two brothers exhaust on it?
looks awesome though.
wstxr6 is offline
Product Review: Bruce Fabrication Exhaust DvlRacer Product Reviews 31 08-31-2010 11:07 PM
Cops Banning All Loud Exhaust Over Here!!... GET CARTER General Discussions 40 04-02-2009 10:50 PM
No Exhaust Kelm Exhaust and fuel delivery 32 06-05-2008 07:38 PM
Exhaust Idea but have some questions ryry Exhaust and fuel delivery 11 11-20-2007 07:21 AM
got my wolf exhaust yesterday adobo Exhaust and fuel delivery 21 02-11-2005 01:14 PM
