Bazzaz installation: pics and editorials added - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 283 (permalink) Old 12-10-2008, 07:31 PM Thread Starter
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
Post Bazzaz installation: pics and editorials added
(for the search function)
Bazzaz installation on the 2006 and 2007 Yamaha R6
well, the standard install instructions on this unit weren't the best. first of all, they REALLY needed a few pics b/c the area under the tank is a freakin' rats nest of wires/harnesses/cables/lines/etc. secondly, not everyone has a service manual, and getting one isn't always legal. thirdly, a few of these harnesses will fit into more than one location, and if done wrong, will probably ROYALLY screw your bike up. so, along the process, i decided to snap a few shots. i did forget a few of them during the install, so forgive the "afterthought" feel of a few of them (b/c i went back and snapped those as well).
what i'm going to do, is simply type out the standard Bazzaz installation instructions, and add my pics and comments to them. i hope somebody benefits from this thread, b/c it's going to take me about an hour, and i'm SURE i'll get some heat from the wife for being on a motorcycle forum while she bathes/puts the kids to bed. oh well
(blue is all my comments/suggestions/ideas)
_______________________________________________
Before you start, i'd recommend you take the tank off. There are two electrical harnesses that hook up, a white one and a green one. i marked the tank side of the harness on the green one with a green marker so i would know which one went back where (they are the same style harness for both cables). then, from the left side of the bike, you'll see two "vent" hoses with metal clamps keeping them attached to the fuel pump/tank. disconnect those, as well as the fuel line (slide the "locker" out, then pinch), from the bottom of the tank, and then remove the tank and set aside. no additional gas will come out of the tank. it WILL come out a little from the fuel line that you will disconnect, as well as the white hard plastic piece on the tank. no worries... use a rag. make sure you're not indoors.
i also took off the tail section (the upper portion of it) and removed the tank mounting bracket (by the battery) as well as the aluminum piece that the main seat sits on (towards the back... attached with four 4mm allan bolts).
We strongly suggest that an experienced technician install this Bazzaz product
1) Place the Z-Fi control unit in the tail section of the bike
plug the main cable harness into the unit
2) Route the fuel harness on the left hand side of the bike
i ziptied mine in a couple spots with some of the other cables that were there to keep things clean along the way... don't get em too tight, as you'll probably need to massage the location a bit at the end.
3) Plug the Z-Fi harness in-line with the lower injectors (yellow tag on harness is cyl#1 lower injector)
the cylinders will be (obviously, i thought) #1 on the far left, and #4 on the far right). the harness has 4 staggered connections, each a little further out. this will PROBABLY be one of the easier things to figure out.
Warning! Make sure the the Z-Fi harness injector male pins make proper contact with the stock harness injector connectors.
4) Plug the Z-Fi harness in-line with the upper injectors
this was a beyotch to find for me... so once i followed the electrical connection FROM the upper injectors down and around, i found the harness. on mine, it was at the very bottom of the left side, under the tank. it's circled in the pic below... look carefully.
5) Locate the throttle position sensor. Pull back the insulation and expose the (1) black/blue and the (2) blue wire. connect the blue wire the the Z-Fi harness to the blue wire on the OEM harness. now connect the gray wire from the Z-Fi harness to the black/blue wire on the OEM harness using the supplied scotchlok.
this was a booger, b/c the one you need to splice into is actually butted up RIGHT next to the right side of the frame, and the clasp that holds the harness together can't be reached with a human finger. period. i have a set of mini-pliers, and one of them is a curved-end "needle nose" or whatever, and i wedged that in and popped the latch, and pulled it apart. good luck... it's a PITA. the next thing you'll notice (at least i did) is that the first wire IS black/blue. the next one is blue and SO IS THE ONE AFTER THAT. i simply used the first blue one, directly next to the black/blue one and it worked just fine. (they have a picture showing the blue Z-Fi wire spliced into the second wire in the harness, which is the reason i went ahead with that particular "blue" wire)
6) Plug the Z-Fi harness in-line with the RPM sensor
this one took me a few minutes to figure out, but the "rpm sensor" is the same thing as the crank position sensor that the service manual refers to. it's on the right side of the "rat's nest" under the tank. i've circled it below. (there are two that are very simliar. the harness with two wires is the rpm/crank sensor and the other one is the neutral sensor (and the directions don't say anything about that one, but you'll still need to plug the Z-Fi harness into that one)
7) Plug the Z-Fi harness in-line with the speed sensor
it's the same vacinity as the rpm/crank sensor and the neutral sensor. it's the trianlgle shaped harness with 3 wires. you might have to dig a little for it. (below is what it will look like after you clip the Bazzaz into the circuit).
*if you have a speedoDRD or speedo healer, "it's better if the Bazzaz reads the original signal from the sensor, before it gets modified by the DRD. The Bazzaz does not alter the signal in any way, the two connectors allow us to splice into the signal without having to actually physically splice into the wire. So, one last time just to be clear: Sensor>Bazzaz>DRD>ECU." (quote, courtesy of Bazzaz)
8) Attach the ground lug from the Z-Fi to the crankcase using one of the crankcase bolts.
look in the middle of the "nest" at the VERY bottom of that area. you'll see a couple black wires bolted with a (i believe) a 4mm allan bolt to the frame. undo that (i used my t-handle wrenches) and simply slipped the ground onto the bolt, and reinserted it and tightened it back down. it's pretty straight forward. (no pics... sorry)
9) Locate the rear brake light connector (3 pin white triangle connector). Pull back the insulation to expose blue/red wire. Using supplied scotchlok now connect the switched power (red tag) from the Z-Fi harness to the blue/red wire on the OEM harness.
Warning! Proper alignment of the t-tap terminal with the scotchlok is critical for proper operation.
10) disconnect the stock O2 sensor fromt he OEM harness and leave unplugged.
follow the sensor up from the exhaust, and you'll find the harness.
this is what mine turned out looking like after i cleaned up and organized the wiring using my zip-ties. try and get as much slack to the unit itself so you can access the mini-usb port on the harness side of the box (learned this the hard way, and am now having to come up with a solution).
overall, i would rate this install as a 7 on a 1-10 scale, with a PC3 install being a 3, and full exhaust being a 5. i would say to just take your time, and make it be neat. this is your electrical system AND your fuel system you're playing with. DON'T SCREW IT UP b/c they don't mix that well.
hope this helped/helps someone. i know i coulda used it. good luck fellas!
Agg2001 is offline
post #2 of 283 (permalink) Old 12-10-2008, 07:35 PM
Bike: '08 R6
Re: Bazzaz installation: pics and editorials added
thanks agg, nice write up!
snowbizx is offline
post #3 of 283 (permalink) Old 12-10-2008, 07:38 PM
IDADONE
14U2NV's Avatar
Bike: 08 R6
I have to say you did a good job, Now if it quits snowing you can go for a ride .Gotta love Texas weather !!!!!! I think I'll have another
now.
'My friends, we live in the greatest nation in the history of the world.
I hope you'll join with me as we try to change it.'
-- Barack Obama
''Life's tough......it's even tougher if you're stupid.''
-- John Wayne
14U2NV is offline
post #4 of 283 (permalink) Old 12-10-2008, 09:19 PM
Focus
zac5876's Avatar
Bike: 06 R6
now.
Haha, I'm just south of you, weird weather!!
Anyway, very nice write up. Just in time, ordered mine last week. Thanks!
zac5876 is offline
post #5 of 283 (permalink) Old 12-10-2008, 10:36 PM
Riding his own ride...
gsxcorey's Avatar
very nice write up! Yes their instructions could surely use some work...
Corey
gsxcorey is offline
post #6 of 283 (permalink) Old 12-11-2008, 02:51 PM
IDADONE
14U2NV's Avatar
Bike: 08 R6
Wherebouts are you in H-town ?
-- Barack Obama
-- John Wayne
14U2NV is offline
post #7 of 283 (permalink) Old 12-11-2008, 03:28 PM
Focus
zac5876's Avatar
Bike: 06 R6
Kingwood and humble area. So I guess south east of you.
zac5876 is offline
post #8 of 283 (permalink) Old 01-16-2009, 12:41 PM
Iwakuni Binjo Bomber
ichibon_kokojin's Avatar
Bike: R6 2007 (Sweet FKN Red)
Good deal... I have PCIII and will try bazzaz with my next bike... maybe by then the instructions will be better.
Two wheels or on all 4s I love riding my girl...
ichibon_kokojin "the" BlackJap
ichibon_kokojin is offline
post #9 of 283 (permalink) Old 02-07-2009, 03:15 PM
track addiction,got cash?
kiaya420's Avatar
Bike: 06 r6
thanks alot agg.if not for your write up, with the pictures(very big thank you for the pictures)i would have been ripping my hair out doing this mod.the best part was when ever i got stuck i would just come back to this writeup and it would help me find the plug i was looking for.only one i had a hard time with was the nuetral sensor, had to look around for plug with matching number of wires.but without this thread i would have been lost,thanks again took me about 3 hrs to do everything instead of who knows .now iam just waiting for my leo full exhaust, and i will then tackle the mapping.thanks for taking the time to do the writeup,very helpful.
kiaya420 is offline
post #10 of 283 (permalink) Old 02-07-2009, 05:02 PM
Nut 'N Bitch
atmueller08's Avatar
Bike: 07 R6 - Blue
Yes thank you agg. it helped me out in a big way.
-Just a thought...for the throttle position sensor. I used a flat blade screw driver and reached from the outside of my fairings and just pressed on the latch and wiggled connection and it came right out. took 3.5 seconds.
-Get Well Soon T-1. Thoughts are with you buddy-
Originally Posted by inkdrips View Post
and if you had any common sense, you'd know that you're more likely to kill someone else on a track than on a highway.
2007 Yamaha R6
Performance
-Full Leo Vince SKB Carbon Exhaust
-Bazzaz ZFI Module
-Bazzaz ZAFM Self Mapping
-BMC Race Filter
-Grave Smog Block-offs
-Driven -1 Front Sprocket
-Air Intake Mod
atmueller08 is offline
