How to do... Keyless ignition.... - Page 16 - Yamaha R6 Forum: YZF-R6 Forums
post #151 of 179 (permalink) Old 12-07-2012, 06:43 AM
Theturtle7023
theturtle7023's Avatar
Bike: 2007 R6S, 2007 R6R
Re: How to do... Keyless ignition....
Originally Posted by Caliboy View Post
question, im not sure if its been answered already or not but, if i do keyless on my bike will my headlights still work?
Dude, if you need your headlights to work, it is a street bike. Why would you want to get rid of the one theft prevention device on the bike? They are already easy enough to hot wire, but you don't need to make it easier.
theturtle7023 is offline
post #152 of 179 (permalink) Old 12-07-2012, 12:03 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
The answer to your questions is yes.
-Jamie M.
toysareforboys is offline
post #153 of 179 (permalink) Old 12-07-2012, 03:17 PM
Vroommm
PacmanR6's Avatar
Bike: White Rice
Send a message via AIM to PacmanR6
Headlights and everything else will still work... I know a few people who have keyless ignition on street legal bikes. One uses it on his stunt bike just so he can remove the ignition, but he also has a RFID alarm that cuts the ignition if the alarm isn't near the bike. A few others hide a secondary cut off switch as well. Even on my track bike I have a secondary switch hidden.
PacmanR6 is offline
post #154 of 179 (permalink) Old 08-07-2013, 10:33 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Bump for a good diy.
Did this today.
Sent from
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #155 of 179 (permalink) Old 08-08-2013, 03:30 PM
has anyone used an OEM switch to do this? i see all these horrible DIY hack jobs on here and would much prefer a clean setup.
u_mirrin86 is offline
post #156 of 179 (permalink) Old 08-08-2013, 03:48 PM
When in doubtThrottle out
mercenary's Avatar
Bike: Always Under Construction
It can be wired to the kill switch but then you lose some function of the diagnostics mode.
2009 YZF-R6
2010 Ninja 250
MCRA/CCS#81
Originally Posted by doctorv
I was wrong.
Quote taken 7-16-15 @ 0640CDT
mercenary is offline
post #157 of 179 (permalink) Old 08-08-2013, 05:20 PM
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 15 Ninja300
You can easily use the high beam switch to do it. There is an incoming line, and the switch toggles between two outputs. Just leave the low beam output disconnected, and hook up the ignition wires to the input, and the high beam output. Simple and clean.
HIS OWN 6 is offline
post #158 of 179 (permalink) Old 09-18-2013, 03:54 PM
Without Warning
frzburn's Avatar
Bike: '09 R6
Here's another twist: Use the horn button as a push-ON/hold-OFF switch.
Check this thread:
'09 R6
Puig DB | eBay Levers | Woodcraft Rearsets | SpeedoDRD
AGG Smog Block-Offs | DID 520 ERV3 | Renthal 46T Sprocket | BMC Air Filter | BAUCE Racing ECU Flash
frzburn is offline
post #159 of 179 (permalink) Old 10-24-2013, 06:59 AM
NoAgendaRacing
nevenelestate's Avatar
Bike: none at the moment
some of the OP pic links are bad....
CCS#193A --
nevenelestate is offline
post #160 of 179 (permalink) Old 03-27-2014, 03:59 PM
leila's Avatar
Bike: 2004 R6 & 2003 GSXR 600
need help!!!!! did what the post told me to do. connected 2 small wires and then brown and red to switch. bike only starts with clutch pulled in and then cuts off when released. the ecu rings constantly now. its a race bike i am removing the ignition from.. anyone have any ideas?
The Louisiana Purchase
Matt Mladin suit on R6 LMAO!!!!
leila is offline
Keyless ignition mod for track bike r6addict How To's... 146 03-31-2016 05:31 PM
Can't get Ignition Bolts out!!! 04YamahaR6IL Garage / Mechanical Help 11 05-14-2012 04:02 PM
Keyless Ignition ishp2005 How To's... 5 05-30-2008 11:25 AM
MSD Digital Ignition Symbiote R6 Garage / Mechanical Help 4 06-13-2007 07:27 PM
Stuck ignition The_RippeR Garage / Mechanical Help 4 10-06-2006 02:42 AM
