How to: Clean and Lube Chain - Page 12 - Yamaha R6 Forum: YZF-R6 Forums
post #111 of 114 (permalink) Old 11-25-2012, 01:32 PM
R6y Business
r6cer88's Avatar
Bike: 2009 Yamaha YZF-R6
Re: How to: Clean and Lube Chain
Originally Posted by mercenary View Post
The middle of the bottom part of the chain should have between 1-1.5 inch play from hanging freely to a high as you can push it with your finger.
Thanks Mercenary! I will be sure to check.
Is there a good thread on how to loosen/tighten the chain? I tried searching but could not find anything good. I have an 09.
Embrace your fear and turn it into drive
r6cer88 is offline
post #112 of 114 (permalink) Old 11-25-2012, 02:58 PM
Yeah Science!
wutsup's Avatar
Bike: gixxer chrome edition
It's quite simple.
1. Loosen up the rear axle nut
2. You will see two locknuts, and within those two locknuts, you'll see the adjuster allen bolts. Loosen up the lock nuts, then turn the inner allen bolt right to loosen the chain, and turn it left to tighten it.
3. Do it one side at a time little by little until you reach the desired chain tension. Check the chain in several different spots. If you have loose and tight spots, it's probably time for new chain and sprockets.
4. Use the lines on the chain adjusters make sure it is aligned/straight. It is not 100% accurate but it should be fine for the most part. If you want to really make sure it is straight, there are several ways, just google and some methods should show up, such as the string method, digital caliper, motion pro also sells a tool to see if you're chain is straight.
5.After you adjust the chain, put an allen key or screwdriver in between the sprocket and chain, and turn the rear wheel so it puts all the tension towars the adjusters. Then tighten up the rear axle nut to spec, then the locknuts on the chain adjusters. ALL DONE!
Someone correct me if I missed something or gave out false information
Chris
06 GSXR 750
08 Track R6 RIP
wutsup is offline
post #113 of 114 (permalink) Old 11-25-2012, 09:19 PM
"The Dude abides .. "
MELK-MAN's Avatar
What picture of my chain are you referring to? I don't really have any pictures up that show my chain at all.
The chain hasn't been tightened since I got it from the dealer a year ago though. But then again, I shouldn't exactly be relying on them to deliver me a perfect vehicle either I guess.
How loose should it be exactly?
my bad.. you quoted 317rider and with 4 huge photos, it just looked like you posted all that stuff.
And yes, what those guys just said. ya need free play in the chain.
www.facebook.com/greg.melka.1
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline
post #114 of 114 (permalink) Old 05-04-2013, 08:44 PM
TwistedRoads's Avatar
Bike: 2012 Black/White R6
Originally Posted by Dakota11 View Post
Never have used kerosine...I do need a rear wheel stand so I can rotate the wheel though. I have to lube it in sections. Stand up move the bike forward, lube, move bike forward, lube. lol getting tired of doing it like that
Originally Posted by LovemyYamahaR6 View Post
use jack stands.
Edit***
NVM
Thread bump
How does the jack stand method work? Still need to buy a set of stands myself.
TwistedRoads is offline
Answer This Question About Cleaning & Lubing Your Chain. porkrinds General Discussions 30 07-02-2010 10:24 PM
Wut do yall use for chain lube...ive tried a few NightRiderSVT General Discussions 2 08-26-2008 09:02 PM
clean and lube a new chain? brandonbigdog Oil and Lubrication 5 06-20-2008 11:04 PM
anyone lube their chain w/ motor oil? vi3tguy04 General Discussions 24 04-04-2008 10:58 PM
