How to Clean TPS 03-05R6 06+ R6s - Page 8 - Yamaha R6 Forum: YZF-R6 Forums
post #71 of 102 (permalink) Old 07-04-2012, 07:51 PM
Wishing I was in PA
BlanksR6's Avatar
Bike: 2004 R6
Very nice write up 03Raven! I plan to do this very soon. I took my bike to a shop to have it fully serviced and ever since i got it back it doesnt run the same,stupid f****s. This seems easy and i will do myself before i have a different shop look at it. Ill post up how it worked out...!Thx again!
Sent from space
BlanksR6 is offline
post #72 of 102 (permalink) Old 07-05-2012, 04:20 PM
Re: How to Clean TPS 03-05R6 06+ R6s
I bought an 2010 R6 with approximately 2.100 miles, I used to have an XT660R before it, and the ECU and TPS works the same way.
Checking out the DIAG mode I found that my TPS full open position gets only 58~59, and the close position about 17.
Iīm from Brasil, and Yamaha donīt sell R6 here, only R1, so no one knows a lot about this bike.
I called to a Yamaha dealer on Orlando but the guy donīt know what is happening too.
I have PC installed on it.
Hope someone can help me with this.
Thankīs
frango is offline
post #73 of 102 (permalink) Old 07-05-2012, 04:41 PM
Nerd dick
Pocket_Rocket's Avatar
Bike: 2005 R6
Thankīs
sounds like your TPS is bad. you might want to order a new one, install it and check the values to make sure its within spec. at the percentage your talking about, sounds like your acceleration must be pretty slow.
03 R6-Special Edition (Sold)
04 R6-Red/blk (Sold)
Proud owner of a 05 red/blk beast
K&N, Yoshi carbon exhaust, PCIII, AGG Racing DRD & Smog off plates, -1+2 driven sprockets.
My 05 Build page
(updated 7/2/2012)
brakes are like being with a girl, better to use 2 fingers
Pocket_Rocket is offline
post #74 of 102 (permalink) Old 07-05-2012, 05:36 PM
I have never ride an R6 before, but i feel that it have more power for me, itīs kind of lazy.
I rode 750 and 1000, never an 600 before, but i can feel that the acceleration is slow.
The codes 14 and 15 works perfectly, goes to 101
The codes 01 and 13 gets the same value, arround 61
Will try to clean the TPS and see what i get
Thank you
frango is offline
post #75 of 102 (permalink) Old 07-06-2012, 05:07 AM
I wasnīt able to remove the cowling, but I loose the screws and didnīt get access to TPS, because have a lot thick cable in front of it.
Will order a new one in US and when it arrive i will replace.
To much work to try to fix and maybe it donīt work
frango is offline
post #76 of 102 (permalink) Old 07-06-2012, 09:11 PM
Wishing I was in PA
BlanksR6's Avatar
Bike: 2004 R6
Just did this today! Followed it every step & it worked great. Mine low/high was 15-94 to start. Now its 17-96
couldnt get it to 97. Probably just had to tweak with it a little more but i was happy with that. Idle is perfect now! So happy :-) thx
Sent from space
BlanksR6 is offline
post #77 of 102 (permalink) Old 07-15-2012, 01:20 PM
Great write up!! I just did mine yesterday on my 03, factory setting was 16-95 best I could get it back to was 17-96! I did notice the oring had a little crack in it! Should I replace it? Ad if so I'm sure it's a Yamaha part I can't just go to the hardware store and get a new oring? Put it all back together and she idles great! Just havent rode it at all yet, the oring has me curious if I should just change it?
smokinsmitty is offline
post #78 of 102 (permalink) Old 07-16-2012, 09:43 AM
Nerd dick
Bike: 2005 R6
if you find a matching size/style then sure hardware store should be fine. unless you like spending $5 on a round piece of rubber be my guess
. some of the screws on my fairing were purchased from a HW store, i didn't feel like spending $15 on a few bolts...
My 05 Build page
(updated 7/2/2012)
post #79 of 102 (permalink) Old 11-05-2012, 03:00 PM
Tron has corrupted me
BigShepp's Avatar
Bike: 2005 R6 Raven "Deimos"
Two quick questions:
What are the symptoms of needing to clean the TPS?
Also what sort of diagnostic equipment is necessary?
Hard work yields great rewards, but idle talk leads only to destruction.
Proverbs 14:23
“Faster, Faster, Until The Thrill Of Speed Overcomes The Fear Of Death.”
Hunter S. Thompson
"It wasn't until I went to college and I got my first motorcycle that I understood the thrill of speed."
Vin Diesel
BigShepp is offline
post #80 of 102 (permalink) Old 11-05-2012, 03:51 PM
Nerd dick
Bike: 2005 R6
its more of a maintenance thing unless your throttle response is going to crap, and the equipment needed is all listed on page 1.
My 05 Build page
(updated 7/2/2012)
2005 Yamaha R6 one owner, 5k miles, clean title, runs great! tudes Bikes For Sale 2 07-30-2009 07:34 AM
How clean is clean? tboozan Garage / Mechanical Help 6 09-04-2008 03:02 PM
How often you clean your bike???? guccigucci2001 General Discussions 35 03-29-2008 09:58 PM
Getting your rims clean? CooperR6 How To's... 33 07-17-2007 07:45 AM
how do you clean your leather..... munoxide General Discussions 16 09-25-2006 12:39 PM
