Router Problems - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 9 (permalink) Old 09-10-2012, 03:38 PM Thread Starter
I have 2 belly buttons.
shad0ws's Avatar
Bike: '09 R6
Router Problems
Well about a month ago, I switched routers from an old d-link probably 5 years old to a newer linksys router. Used to get download speeds averaging in the 800kb/s range spiking to 1400kb/s on the average file download. Now that I've switched routers I can't even break 400kb/s. I really have no idea of where to start with this, anybody have any insight?
shad0ws is offline
post #2 of 9 (permalink) Old 09-10-2012, 03:42 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: Router Problems
It shouldn't have made much difference honestly. You will more than likely need to open your web browser and goto the IP address for the router and check the settings for the NAT'ing and see if it has a firewall built into it, etc.
If you're on wifi maybe the signal is weak. Maybe it operates at the frequency and channel your home cordless phone does! Troubleshooting an issue like this is the pits. Especially since internet speeds vary on how many users there are, time of day, etc.
CONTACT/EMAIL ME HERE
R6 ECU FLASH Click Here
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -NGK- -EBC- -Canyon Dancer-
ChiefSmokeDawg is offline
post #3 of 9 (permalink) Old 09-10-2012, 04:05 PM
Bike: 07 R6
Re: Router Problems
reseting the router usually works for me.
LadyR6 is offline
post #4 of 9 (permalink) Old 09-10-2012, 06:09 PM
slouche
KBkilla's Avatar
Bike: 2012 R6
Re: Router Problems
What model Linksys did you get? If it's one of the new E1XXX series, try switching the the wireless channel width to 20Mhz only instead of Auto. You can do this by opening your browser and going to 192.168.1.1. The username and password should be admin for both.
Also, like Chief said, it could be operating at the same channel frequency as other wireless devices in your home. If you have an Android device, download an app called Wifi Analyzer. This will scan all wireless channels within range and show you which ones have the most traffic. You can change your router to operate at the least busiest frequency, and that should improve it if the first suggestion doesn't fix it.
EDIT: Also, who is your ISP?
KBkilla is offline
post #5 of 9 (permalink) Old 09-10-2012, 06:39 PM
Smoove910's Avatar
Bike: 2007 R6s
Re: Router Problems
first thing to know is if you are wired or wireless... I agree with Chief though, you should look at changing the channel to see if you get less interference.
Smoove910 is offline
post #6 of 9 (permalink) Old 09-10-2012, 06:44 PM
jmk1223's Avatar
Bike: 06 R6
Re: Router Problems
Only 3 channels are truly unique (1,6,11) so I would suggest switching to one of those three. Then check download speed with a direct connection to the router(http://speedtest.net/) and then try it through the router to see if it's any slower. I'm a network engineer for an ISP so if you have any questions feel free to PM me.
jmk1223 is offline
post #7 of 9 (permalink) Old 09-10-2012, 11:56 PM Thread Starter
shad0ws's Avatar
Bike: '09 R6
ISP is Comcast or xfinity, whatever they call themselves these days. I'm running the computer wired right now. Wireless is equally slow. And yes it is one of the new linksys routers. Its a E1550.
shad0ws is offline
post #8 of 9 (permalink) Old 10-03-2012, 05:47 PM
Nothing lasts forever.
bzdkid's Avatar
Bike: 2008 R6, All Black.
Try all of the following things-
Set channel frequencies to Auto (20 or 40 MHz)
Make sure your network is secured by WPA passphrase at least.
As said above, channels 1/6/11 are good but I'd say set it to auto.
Set key renewal to 3600 seconds.
Check your DNS settings and verify the DNS addresses are all correct.
And make sure the following settings are as shown in defaults in the attached image:
If all else fails, power cycle your router and modem by turning them off for 2-3 minutes and back again.
bzdkid is offline
post #9 of 9 (permalink) Old 11-18-2012, 08:18 PM
Re: Router Problems
I experienced switching routers before and it didn't affect my speed. If I do get intermittent signals, I would simply power cycle and everything goes back to normal. If you try using your old router (if you still have it) and the speed remains, then the issue truly is with your new router, but if you get the current speed using your old router, then contacting the tech support of your ISP might be a good idea.
TScott27 is offline
PC help: wireless router heywood jablomy Off Topic Talk 19 12-28-2009 04:58 AM
Router Help!!!!! :( J.DenhamR6 The Computer Guru Section 4 12-15-2008 11:41 PM
resetting my wireless router passphrase HELP! burk Off Topic Talk 15 01-01-2008 12:24 AM
For Sale - Wireless Network Router, PCI Card, and Laptop Card danrivito Off Topic Talk 1 02-03-2006 09:14 PM
Router issues with XBConnect Evilr6 The Computer Guru Section 10 03-16-2005 06:15 AM
