Shock springs???? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 13 (permalink) Old 03-02-2012, 02:34 PM Thread Starter
Only Jealous Ones Envy
Envycycles's Avatar
Shock springs????
Hey guys I have a stock 08 R6 shock with Traxxion valving but I need a spring for my weight since Im about 50lbs heavier than the previous owner.
I looked at the racetech site and it tells me a 10.7-105N is what I need but I have heard that the site is not accurate.
How I make sure on what I need? Also I see there are some brands that are in lbs/in how do I convert it back and forth?
Another question: Can I replace the spring with out a spring compression tool? I heard some guys saying you can do it with zipties.
I also have a Ohlins YA606 that I need to replace the spring (same question for this).
I see on ebay springs for sale but how do I know how to buy one?
Envycycles is offline
post #2 of 13 (permalink) Old 03-02-2012, 02:42 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
For the ohlins shock I'd call ohlins. They are very helpful.
Regarding the other shock with the valves, I'd call racetech. Cause the valves in there may not be ideal for the new spring rate
ChiefSmokeDawg is offline
post #3 of 13 (permalink) Old 03-05-2012, 07:19 AM Thread Starter
Envycycles's Avatar
Re: Shock springs????
OK so Im borrowing a compressor tool.
Now Im looking about springs.
I understand I call either racetech or ohlins but I want to buy some hyperco springa that are on ebay new.
post #4 of 13 (permalink) Old 03-05-2012, 08:07 AM
Parts Pimp
Great, then determine the correct rate and use online conversion tools to get the rate converted into the units you need for these hyperco springs
post #5 of 13 (permalink) Old 03-06-2012, 10:53 PM Thread Starter
Envycycles's Avatar
Got the info needed.
The spring needs to be 2.25" x 6"
post #6 of 13 (permalink) Old 03-12-2012, 05:14 PM
Bike: 08 R6 track bike
with race tech u need a new preload adjuster to fit on the stock shock, i just found k-tech, n i think that spring is a direct replacement, but i only found that company recently and it think its in europe, so maybe with the price of shipping n the over priced spring u can just get it all from race tech.... i was also looking for a spring but dont have the money for the preload adjuster so im just gonna deal with it for now, its just over sprung for me, im too light so its not that bad
arrhsix is offline
post #7 of 13 (permalink) Old 03-13-2012, 02:24 PM
Bike: 03 R6
Images: 2
the guys at penske and racetech both told me the stock rear springs on the R6 are good enough for a 250 lb rider. the springs they use for most guys are way lighter than the stock spring.
the front fork springs are the ones you need to change the most(stronger)
blue03r6 is offline
post #8 of 13 (permalink) Old 08-16-2012, 07:27 PM
Are all the Shocks from 06-12 all sprung the same from the factory. I would like a higher spring rate than what is on my 2010 without going through the trouble of a revale/respring. If there was a particular year that came with a higher spring rate from the factory I might just find one used I could try.
stretch160 is offline
post #9 of 13 (permalink) Old 08-25-2012, 01:48 PM
Go hard or go home
Bike: R6, GSX1400
All R6'S after 06 are sprung stiff on the rear (1.03) and soft at the front (0.92).
Depending on valving in the shock you would need a substantial amount of mass to need a firmer rear spring than this. Most of the time softer is the way to go.
Online spring calculators are just a guide and not the golden rule as the same weight riders can have vastly different spring requirements from riding style alone. This makes it quite difficult if you are buying a spring. Best suggestion is to make contact with someone local that does suspension and work with them. This way you work in a focused direction rather than trying different suggestions that are made without all the facts.
kiwiracer is offline
post #10 of 13 (permalink) Old 08-26-2012, 02:33 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
+1 on finding someone local to work with. If my shop has the spring I'm looking for in stock they'll let me swap with whatever spring I have for free (or cost of labor if they're physically swapping it out for me).
Fallis is offline
Rear shock/fork springs & riding 2-up? Zexel Suspension settings 9 11-02-2010 03:26 PM
Need to change fork and shock springs Bigtony Suspension settings 2 01-19-2009 07:21 AM
need to replace fork and shock springs Bigtony Suspension settings 0 01-18-2009 08:44 PM
Opinion on Hyperpro Combi kit (rising rate front springs & rear shock spring) JTRC51 Suspension settings 1 10-27-2008 10:06 AM
Ohlins and Fork Springs and Rear Shock Spring ambasnakeman Suspension settings 0 04-01-2007 10:33 PM
