triple tree conversion question - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 09-28-2012, 11:24 AM Thread Starter
I have a 2005 R6. Im looking to change over my 05 triple tree for an 06 triple tree. However, I have read that this will change the rake of my bike from 24.5 to 24. What all does this mean for general handeling/suspension of the bike on the street. Also, I may want to take the bike to the track in a year or two, so is this rake difference a good or bad idea?
Thanks for your input.
rob
geaux saints!
rjz1 is offline
post #2 of 8 (permalink) Old 09-28-2012, 11:58 AM
Stunt Rider
ridick_bowen's Avatar
Bike: R6/R1 Hybrid
Re: triple tree conversion question
I don't think that will work. The offset will be different. It won't line up.
R6/R1 hybrid
ridick_bowen is offline
post #3 of 8 (permalink) Old 11-12-2012, 04:09 PM
The Reverend
!!A2K!!'s Avatar
Bike: 05/2012 r6 stunter!!!
Wont work.....it either needs to be 05 upper and lower or 06+ upper and lower. They WILL not work if you try to put 05 top on 06+ bootom and vice versa
redlinemotorsports.biz
galferusa.com
durtys powder coating
racetech.com
jbseatz.com
c4-revolutions.com
Samcosportusa.com
motydesign.com
!!A2K!! is offline
post #4 of 8 (permalink) Old 11-12-2012, 04:32 PM Thread Starter
ok. thank you for the advice!
rob
rjz1 is offline
post #5 of 8 (permalink) Old 11-12-2012, 05:22 PM
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
You can do it, but you have to have everything from an 06 or whatever bike. The 05 is unique to that year only and is incompatible with anything from any other year.
luke geis is offline
post #6 of 8 (permalink) Old 11-12-2012, 05:38 PM Thread Starter
luke, 05 front suspension is incompatible with any other year, or all 05 parts are incompatible with any other year (rear swing, suspension, engine, brakes, etc.)?
btw- i found an 05 upper triple tree and am back on the road.
rjz1 is offline
post #7 of 8 (permalink) Old 11-13-2012, 03:26 AM
luke geis's Avatar
Bike: 2005 red r6
Images: 10
The front end is unique to that year only. The rear is the same as all the bikes that look like the 03-08 R6/R6S, but different years use different shock bodies. The rear shocks are different lengths and have different spring rates. Hence the red and yellow spring colors. The 05 R6 is the most unique of all the years because it is the only one that has that front end and engine combo. The 05 has a slightly different intake track from the other years.
Basically nothing on the 05 front end will work on, or with front end parts from any other year. You can put any rear ( from similar style bike ) on any year as well as any rear part. The front is the only thing totally incompatible.
This only apples to the major suspension parts though. I.E the triple tree, triple clamp, forks and clip ons. However if you have an entire 06 R6v front end, it can be a direct swap. The new 06 front end is longer and will change ride height in the front end, but can be worked around.
post #8 of 8 (permalink) Old 11-13-2012, 08:08 AM
The Reverend
!!A2K!!'s Avatar
^ you will also need a spacer for the triple becuase the steering stem on the r6v is a little longer than the one for the r6s
galferusa.com
racetech.com
jbseatz.com
c4-revolutions.com
Samcosportusa.com
motydesign.com
!!A2K!! is offline
WTB 08 and up Lower triple triple tree Havoc1 Bikes + Parts + Gear Wanted 0 06-29-2012 11:32 AM
FS: 2008/2009 Upper Triple Tree, and 2006/2007 Lower Triple Tree choleaoum Bike Parts For Sale 2 02-09-2012 06:06 PM
Default 04 R6 forks w/ triple tree, 05 R6 w/ triple tree Black 4.6 Beast Bike Parts For Sale 4 03-04-2009 04:35 PM
06 triple tree clamp question Mkiv General Discussions 9 10-01-2007 01:30 PM
Need lower Triple Tree(triple crown) w.or w.o forks RadicalR6 Bike Parts For Sale 1 07-18-2007 12:41 PM
