Fork height - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 14 (permalink) Old 10-08-2012, 04:27 PM Thread Starter
johnjon1180's Avatar
Fork height
Hi everyone so I just bought a 06 r6 and want to know what the stock line of the front forks in the triple are set at. Was just wondering what track ppl are running ? 1st line, 2nd line, or 3rd line thanks
"Apex Addict"
johnjon1180 is offline
post #2 of 14 (permalink) Old 10-08-2012, 05:01 PM
AFM #723
Doc-Ram's Avatar
Bike: 08R6, 16R3, 15R3, 07 150R
Flush with the triples for track. I'm running that on my 08 as well now.
Sent from my iPhone using MO Free
AFM #723
2017 Sponsors:
Doc-Ram is offline
post #3 of 14 (permalink) Old 10-08-2012, 05:11 PM
OhioYJ's Avatar
Re: Fork height
(Your 06 should be the same as the 07)
OhioYJ is offline
post #4 of 14 (permalink) Old 10-08-2012, 05:31 PM Thread Starter
Thanks guys cause the last owner had them set at the 3rd line which seemed alittle crazy. I noticed most of the newer models are at around the 2nd line but it seems the 06-07 have a shorter fork? I haven't tracked ot yet as I rebuild my 07 r1 after a nasty off this past may and the 06 r6 I just got will be my winter project.
Sent from me Verizon Thunderbolt 4G LTE
post #5 of 14 (permalink) Old 10-08-2012, 05:32 PM
OhioYJ's Avatar
Re: Fork height
06-07 do have shorter forks, the 08+ are 10mm longer, and that 10mm sits about the triple clamp from the factory. 06-07 are flush with the top.
OhioYJ is offline
post #6 of 14 (permalink) Old 10-08-2012, 05:33 PM
Make good choices.
thedub's Avatar
Bike: R6, SV, KTM300, Tiger 800
Re: Fork height
The first time you ride it, put them flush. Then put them down one line. Then put them down two lines, etc. Then decide which you liked best.
thedub is offline
post #7 of 14 (permalink) Old 10-08-2012, 05:46 PM Thread Starter
Cool now I just have to check the rear dogbone links to make sure It wasn't lowered although I dont think it was in the rear. Anyway to check that rear ride height is stock? I did take a quick look at them and they seem to be original
post #8 of 14 (permalink) Old 11-01-2012, 08:17 AM
haburaboi's Avatar
Bike: 2006 R6 Raven
Re: Fork height
donít mean to thread high jack but what happens to the bike if you do raise the forks a bit? what characteristics change? I was going to raise mine up about 4mm so I could install a laptimer bracket onto the top and didnít think this slight increase would change much.
haburaboi is offline
post #9 of 14 (permalink) Old 11-01-2012, 09:14 AM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
Re: Fork height
Generally, it will make the bike turn in quicker, but the flip side is that it will be less stable mid-corner and more twitchy. However, the consensus is that, on the 06-07, the forks are already too short. That is why the 08 got longer forks which raised the front ride height.
8Ball is offline
post #10 of 14 (permalink) Old 11-17-2012, 02:11 AM
Re: Fork height
I got 07 r6 and little bit know about its functions. But when i shift gear bike take time for more pick or speed. Is there any adjustment need which solve this problem.
Clarkjet is offline
03 r6 stock fork height? pady999 Suspension settings 6 05-28-2012 03:53 PM
07 R6 fork height? Ruthless_R6 Suspension settings 8 02-23-2012 09:25 PM
stock fork height on a 99-02 r6 tenacious Suspension settings 2 01-02-2011 03:18 PM
Original Fork Height For 06-10 JuanTon600 How To's... 8 09-08-2010 06:17 AM
fork tube height? Ta Jay Suspension settings 0 08-14-2005 10:40 AM
