2004 R6 fork height - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 12 (permalink) Old 11-27-2012, 09:14 AM
Razor Sharp
Bike: 2003 r6 2005 r6
Re: 2004 R6 fork height
I used to have my forks on my '03 set about where you have pictured, about 25mm down from the clip ons sitting flush with the fork cap. This was done in conjunction with the rear being lowered as well because i used to go to the drag strip frequently. It did ok in the corners but i noticed a night and day difference when i raised that thing back up to stock height in the front and then went about 1/2" to 1" higher than stock in the rear. It has a long way to go before any hard parts are going to scrape. My recommendation would be raise that front end up and see if you like it as much as i did. Also starting with stock settings is a great baseline for adjustments. Also, if the engineers at Yamaha found some sort of advantage in having the forks lower, they most likely would have sent them that way from the factory... Just my $.02
RISKY6 is offline
post #12 of 12 (permalink) Old 11-27-2012, 09:54 AM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
His forks are at the stock height. He just has aftermarket clip-ons that mount below the upper triple clamp.
8Ball is offline
Fork height johnjon1180 Suspension settings 13 11-17-2012 06:30 PM
03 r6 stock fork height? pady999 Suspension settings 6 05-28-2012 04:53 PM
07 R6 fork height? Ruthless_R6 Suspension settings 8 02-23-2012 10:25 PM
Original Fork Height For 06-10 JuanTon600 How To's... 8 09-08-2010 07:17 AM
Help: Fork Height adjusment GEORGERE Garage / Mechanical Help 2 03-03-2008 01:12 AM
