03 r6 rough idle - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 27 (permalink) Old 02-17-2010, 09:07 PM Thread Starter
peter123's Avatar
Bike: '03 R6(sold), 2005 r1
03 r6 rough idle
hi im new to this forum and also new with bikes. I bought my r6 last summer with about 6k miles and it was running great. However a month or so into the season it started having idle problems. The idle cut in and out and it got so low that sometimes the engine would just die. so i had to turn up the idle a bit to like 1800, but it would still sometimes cut in and out. And it didnt just end there, it also, maybe 3 or 4 times the whole season while riding would just die when i pulled in the clutch and when i let go rpms would go back, it would also back fire really bad when this happened. Also when it would idle bad i would turn off the bike and put the power comander in program mode and it would idle fine, and sometimes come back but sometimes not. Could it be a faulty power commander? or maybe the coils? i still have to check whether i got the bad densos or not. And one more thing while riding, keeping the rpms steady at like 5k, the rpms sometimes drop a bit then go back up causing a very tiny jerk.
well im determined to fix this problem before i start riding again so any suggestions will be much appreciated.
thanks
peter123 is offline
post #2 of 27 (permalink) Old 02-17-2010, 10:22 PM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
Re: 03 r6 rough idle
Sounds like coils to me. I did have a problem with a PowerCommander III, the bike would shut off sometimes when decelerating into a turn around 10K rpm. But DynoJet replaced the unit and I've had no problems since. From your description, it sounds like you have a PC V, correct? If so, that is probably not your issue, unless you have a bad connection in the PC wiring harness.
8Ball is offline
post #3 of 27 (permalink) Old 02-18-2010, 07:07 AM Thread Starter
peter123's Avatar
its a power commander III usb. Do you know if the coils would still be covered by that recall if i have the densos
peter123 is offline
post #4 of 27 (permalink) Old 02-19-2010, 09:21 AM
yamaguy's Avatar
Bike: pearl white zx10r
Your yamaha dealer should change them out for free. I had the same problem with my bike looked at the coils and had densos. There was also a recall on the front sprocket nut if i remember correctly. I had to pay for new plugs though, it was like $40. Hope this helps.
yamaguy is offline
post #5 of 27 (permalink) Old 02-19-2010, 12:11 PM
Bike: 03 R6
Images: 2
sounds more like a bad throttle position sensor the 03 and 04 was plagued with.
they are pretty expensive. over $100. and just because it tests good doesn't mean it isn't bad. my buddies tests just fine but we swapped it out with mine and his bike ran perfect.
his was randomly stalling.
blue03r6 is offline
post #6 of 27 (permalink) Old 02-22-2010, 06:56 PM
natedawgg94's Avatar
Bike: just picked up a 03' R6
mine seems to be the same at idle just kinda loading up but once you take it down the road it clears up. i just got the bike about 2 weeks ago weather has been kinda crappy so haven't had a chance to ride much. as far as mods it has a yoshi pipe and k&n filter as far as i know. new to bikes but work on cars a lot so shoot me some stuff to look far. can u take and clean the maf sensor on these bikes like u can on a car??? also thought maybe since the guy just has recharged the filter maybe he put to much oil on it???/ any help would be great
2003 yamaha R6 with frame sliders, k&n filter, and yoshi full exhaust and carbon fiber pipe, and power commander just got here
natedawgg94 is offline
post #7 of 27 (permalink) Old 02-24-2010, 09:24 AM
hhhhmmmmm
Bike: 06 r6
check to see what coils youve got.... you can still get them covered but you need to call yamaha and get an approval code to bring to the dealer (i had to do this last summer)
also as everyone has said there is a known issue with the tps and there is a monitor in the self diagnostic section of the gauge cluster. the FSM will tell u how to find it.
im a master tech with a full shop at my house in keene nh (may not be too far from u) if you need any help just pm me and bring the bike up
I walk tha corner to tha rubble that used to be a library,
Line up' to the mind cemetery now
tech1234 is offline
post #8 of 27 (permalink) Old 02-24-2010, 07:41 PM
Bike: 03 R6
Images: 2
there isn't a MAF on a bike.
they have 4 separate throttle bodies. it could just simply need a good synchronization.
the synch of the throttle bodies plays a big part of the good smooth idle.
with an aftermarket pipe they will fluctuate slightly at idle.(100-300rpm typically)
that's normal.
look at the top of the coils. if they are a light tan epoxy top without any sticker that's the mitsubishi coils that are the good ones.
the bad ones have a black epoxy top with a black and white sticker that says DENSO on it.
blue03r6 is offline
post #9 of 27 (permalink) Old 02-24-2010, 08:03 PM
thanks i'll try to see what i have tomorrow after work.
post #10 of 27 (permalink) Old 02-25-2010, 11:14 AM
well i just finished talking to the guy i got the bike from here at work and he said that the coils have been done about 5k miles ago. he had them done right after he got the bike. Also said the bike would do this in cold weather when he had it but once summer gets here it quits.
2002 R6 Idle Troubles? Irillus Garage / Mechanical Help 12 04-19-2011 01:28 PM
03 R6 doesn't idle high when cold Schrute Farms General Discussions 7 04-18-2009 08:22 AM
05 R6 idle problem Yazman Garage / Mechanical Help 3 04-10-2009 04:24 PM
04 R6 PC3 Sloppy Idle Khojima Garage / Mechanical Help 1 04-01-2009 06:42 AM
Random R6/GSXR parts, rearsets, takesoffs, new tires, ect... FastrnU Bike Parts For Sale 24 09-07-2008 01:57 PM
