Definitive: Chain & Sprocket thread........ - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
post #31 of 79 (permalink) Old 09-05-2012, 07:52 PM
Overboost FTW !
Re: Definitive: Chain & Sprocket thread........
Wow,I have no words to express what I feel. *** king thanks man !!!!!!!!!!!!!!!
Thanks for the good info
OverboostR6 is offline
post #32 of 79 (permalink) Old 10-12-2012, 02:10 AM
Sikor's Avatar
Bike: 2007 YZF-R6
Great article but I still have some questions.
What are the recommended chain lengths for setups -1/+2, -1/+1 and only -1 front on 2007 R6?
I'm currently ridding on -1/+2 520, having chain with 116 links on rear tire 180/55. Some time ago I've ridden chain with 114 links and I had some issues. With the 180/55 I can put on the tire warmer and it slightly touches the swingarm - not a big deal at all. When I rode on a 190/55 tire the distance between the wheel and the swingarm was less but it fitted (although I haven't test it with tire warmes). Once I bought a 180/60 tire and it didn't fit in the swingarm - I couldn't get the rear axle back because of the short chain.
So I'm planning to ride with 3 different gearing setups as I mentioned above. I'm usually riding on 180/55, always with warmers but I'd like to have the opportunity to test 190/55 and 180/60.
Should I left the 116 links chain for every setup? Wouldn't it be too long for -1/+1 and for -1 front, would it? Maybe I should decide to ride on 180/55, get the 114 chain and be sure that it'll work fine with other gearings?
Have you tested these options?
Sikor is offline
post #33 of 79 (permalink) Old 11-09-2012, 09:54 PM Thread Starter
crashing aint so bad
luke geis's Avatar
Bike: 2005 red r6
Images: 10
You can add or remove links as needed for different gearing. The stock number of 116 links will work for the standard -1 +1 and + 2. But can be tight with the +2 on some bikes. It depends on the swing arm depth. The 06 and up don't seem to mind. The 05 and older have less depth adjustment.
I was running a 205 rear for a bit and I had to run a longer 117 link chain to make it work. The 05 swing arm was not deep enough to pull the adjuster all the way back and clear the swing arm with the tire. I was also running -2 +2. So going with a -1 on the front really meant a longer chain. Either that or I had to run a smaller rear sprocket. It never hurst to get a chain with the extra links. Always better to get rid of unneeded links that to have to add new ones. The link is technically master link is the weakest link.
luke geis is offline
post #34 of 79 (permalink) Old 11-10-2012, 03:23 AM
Sikor's Avatar
Bike: 2007 YZF-R6
Thanks. I didn't know that I can add links. Does this mean that I should have 2 or more master links next to each other to extend the chain? Will it be safe while racing and during track days?
Sikor is offline
post #35 of 79 (permalink) Old 12-08-2012, 10:00 AM
Bike: '03 black/red r6
Send a message via AIM to infamouskillas
used the search to find this thread and it is very helpful...learned a lot of new things like different o rings and pros and cons between each...however, I'm sorry to be that noon, but I've read, re-read, and re-read this article again, and I'm still have a little trouble understanding chain pitches in relation to sprockets.
my question is, I understand that a 530 chain is wider, heavier, and thicker then let's say a 520 chain...however, it was to my original understanding that you couldn't use a 520 chain without going -1/+2 with your sprockets...but then I thought that I had read in his article that if you don't wanna lose your top end but want to change your chain, you can run a 520 chain with stock gearing, which is a superior choice being that the chain will be lighter....
but then I read in a reply with the chart of sprocket widths and different pitches, and now I wonder if by using a different width chain, doesn't that mean that you'd need to use certain sprockets to fit the width better?
regardless, everything else made perfect sense to me and wanted to say thanks for taking the time for the write up, definitely helped me know what to look for.
- ian
infamouskillas is offline
post #36 of 79 (permalink) Old 12-08-2012, 10:18 AM
Yamaha R6
Rriggs92's Avatar
Bike: 07 r6
- ian
You don't have to change gearing to run s 520 set up. The chain and sprockets just have to match. As in 520 chain with 520 sprockets. -1+2 just would make you accelerate quicker while sacrificing top speed
Sent from my iPhone using
Rriggs92 is offline
post #37 of 79 (permalink) Old 12-08-2012, 10:27 AM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
^^^ What he said. The 520 WEIGHT chain and sprocket is independent of the gearing ratio. You can run any gear ratio with 520, 530 or 535 weight components, provided they are all the SAME weight (for example, don't try to run 520 weight sprockets with a 530 weight chain). A buyer does not specify the PITCH of a chain-- people on this site need to stop throwing around the word "pitch" when they mean "weight".
pickpocket293 is offline
post #38 of 79 (permalink) Old 12-08-2012, 10:49 AM
makes sense now, thanks a lot I appreciate it!
post #39 of 79 (permalink) Old 12-09-2012, 11:27 AM
Yamaha R6
Rriggs92's Avatar
Bike: 07 r6
Is this the chain/sprocket thread you have in your signature pickpocket? I'm on my phone so I can't see them
Rriggs92 is offline
post #40 of 79 (permalink) Old 12-09-2012, 11:47 AM Thread Starter
luke geis's Avatar
Bike: 2005 red r6
Images: 10
To clear up even more confusion.
You can run just about any gearing combination you desire, so long as the chain and sprockets are of the same type. I.E. 520 chain with 520 sprockets. %30 chain with 530 sprockets.
The " standard " thing to do when changing from a 530 - 520 chain is to go the -1 +2 format. This is just the popular thing to do, not the rule, or must have deal. You can run -2 +1, -0 +4, or even -1 -1 if you desire. It's up to you which gearing you choose.
Chain/Sprocket Kit Illernoise General Discussions 5 05-04-2010 08:28 AM
2003 RJ05 OEM CHAIN KIT (532 chain and sprocket 16t and sprocket 48t) jimae Bike Parts For Sale 0 10-27-2009 05:52 AM
chain and sprocket help plz 03blackr6 Product Reviews 3 03-29-2009 06:38 AM
F/S 06 R6 chain and sprocket RowdyRods Bike Parts For Sale 6 11-23-2007 05:56 PM
FS: 15T Sprocket Specialist Front Sprocket for 06-07 R6- Fits 525 Stock Chain Size mikdivad Bike Parts For Sale 1 07-06-2007 05:16 AM
