Low RPM Sputtering - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 48 (permalink) Old 10-12-2010, 09:08 PM Thread Starter
Bike: 2006 R6 Raven
Low RPM Sputtering
Hi all!
I'm new to this forum after purchasing a 2006 Raven. Overall the bike looked pretty good except for the fact that one fork seal was leaking a little bit, and I have been able to adjust and fix everything except for one thing and I was hoping someone could help me out.
At low RPM's (-4000) my engine kind of sputters a bit so I have to take off at much higher RPM's. I don't know if this is just characteristic of R6's/in-line fours or if it's just me. I just came from a v-twin sv650 so the difference might be what is throwing me off.
anyways, if anyone has any insight, it would be much appreciated. Thanks!
-Steve
sdang50 is offline
post #2 of 48 (permalink) Old 10-12-2010, 09:19 PM
g21owner's Avatar
Bike: 1999 Yamaha R6
Re: Low RPM Sputtering
I had this same problem on my 99. It actually sputtered and died while I was at an intersection and I got rear-ended (Truck just bumped my back tire). I ran some fuel cleaner through it and adjusted the low idle and it's all good now
PS nice bike
g21owner is offline
post #3 of 48 (permalink) Old 10-12-2010, 09:24 PM Thread Starter
Bike: 2006 R6 Raven
PS nice bike
Thanks for the advice!!! Quick question: What kind of fuel cleaner do you recommend using? and also how do you adjust the low idle on the bike? Thanks for the compliment on the bike, right now i'm looking at getting a slip-on exhaust for it looking at Leo Vince and Akropovik trying to figure out the advantages. Thanks again.
-Steve
sdang50 is offline
post #4 of 48 (permalink) Old 10-12-2010, 09:30 PM
g21owner's Avatar
To be honest, I don't remember the name. I know it liquid was blue and I can let you know for sure tomorrow morning. As far as adjusting the idle, on the first gens there is a knob on the right side of the bike just above the clutch cover, not too sure where it's at on an 06.
I really like the Akropovik's, Thats what I have on mine
g21owner is offline
post #5 of 48 (permalink) Old 10-13-2010, 10:31 AM
g21owner's Avatar
hey bro here's the stuff that I used, worked pretty good
g21owner is offline
post #6 of 48 (permalink) Old 10-13-2010, 10:39 AM
190rwhp......:eek5
jwxfd's Avatar
Bike: 2011 S1000RR, 97 CR500
Send a message via Yahoo to jwxfd
Does your 06 have any mods...i.e. exhaust? power commander/fuel controller?
Sig courtesy of the man himself: GIjoe007
jwxfd is offline
post #7 of 48 (permalink) Old 10-13-2010, 11:22 AM Thread Starter
Bike: 2006 R6 Raven
Smile Re: Low RPM Sputtering
Hey! This is SUPER helpful. I'm headed out today to go pick some up. I'll keep you posted.
-Steve
sdang50 is offline
post #8 of 48 (permalink) Old 10-13-2010, 11:23 AM Thread Starter
Bike: 2006 R6 Raven
Nope. My bike is pictured above, completely stock. Do you think that if i mod my bike with an exhaust and power commander that might solve some of my issues?
-Steve
sdang50 is offline
post #9 of 48 (permalink) Old 10-13-2010, 11:27 AM
cheefar6's Avatar
Bike: 2008 YZF-R6 x2
my bike used to sputter a lot when i got it, real bad below 5krpm.
i had quite a bit of problems , and after getting the bike working really smooth to where u can coast around no problem in first gear at 4k rpm, no sputter
ill say you should check on all of these things, as they are pretty simple.
First run through your diagnostic mode, using the service manual (located at r6messagenet.com if u need it)and check each injector.
next, also in diag mode, play with d_01, which shows the value for your tps. just roll on and off the throttle with the bike off and look for smoothness in the numbers, especially when barely on the throttle. make sure it never jumps numbers or anything, but goes up or down smoothly depending on throttle position.
Ive always steered away from the Fuel injector cleaner things because ive had some friends with bad experiences on their cars, and i know on bikes we dont get checked for emission but still, i like the old school SeaFoam treatment. Ive used it in my car with great success using the brake booster line to inject the SeaFoam straight into my engine, and it completely smoothed out my rough idle on the R6. I just followed exact dosage on the back on the bottle after a fresh fill up at a gas station, did this for three gas tanks.
cheefar6 is offline
post #10 of 48 (permalink) Old 10-13-2010, 03:23 PM
Waqsy's Avatar
Bike: 04 R6
What rpm does your bike idle at when warmed up?
I'd give the bike a service (oil+oil filter+spark plugs) considering you'd just bought the bike. Also check the air filter.
I also bought my bike used and that was the first thing I did and I noticed a BIG difference.
Waqsy is offline
Sputtering at 5k on my 99 ErbStang94 Garage / Mechanical Help 5 05-09-2011 11:54 AM
03 R-r Sputtering!>@#$%^& R6-SOTO General Discussions 8 09-20-2010 08:39 AM
sputtering thenameisb2u General Discussions 12 09-20-2010 08:08 AM
on and off low rpm sputtering, plz help ThomasUSMC General Discussions 8 05-09-2010 12:30 PM
help 02 r6 sputtering 02r6jardine Garage / Mechanical Help 11 08-25-2006 04:37 PM
