09 R6 - neutral switch location and 12V cable - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 3 (permalink) Old 11-15-2011, 07:29 AM Thread Starter
Hello all
Im trying to install one of these gear indicators:
and to do so I need to locate 2 things:
- where is the neutral light switch? in the older models it is located next to the rear suspension, is it the same in the '09?
- I need a +12V input. Where would be the best/easiest place to get it from? (ie, I wont like to cut any wires). Taking it from the battery is not an option because it will always be on.
I will post the how-to if I can make it work.
Thanks !!!
-mariano- is offline
post #2 of 3 (permalink) Old 11-15-2011, 07:40 AM
SlowAndOld's Avatar
Bike: 2 kawis and a 03 R6
Re: 09 R6 - neutral switch location and 12V cable
Originally Posted by -mariano- View Post
Hello all
Thanks !!!
Usually they are tapped into the harness behind the cluster directions should tell what colors to tap
SlowAndOld is offline
post #3 of 3 (permalink) Old 11-04-2012, 01:21 PM
Live ride die
animal1000's Avatar
Bike: 08
I'm also thinking of getting one of these gear indicators so could anyone tell me were the neutral switch is on a 08+ Thanks
It was like riding an Epileptic fit...
animal1000 is offline
neutral switch spikek12 Garage / Mechanical Help 14 02-22-2017 01:16 AM
Is it bad to switch from neutral to 2nd? jonLr6 General Discussions 10 04-19-2016 02:48 PM
neutral switch solidgooold Garage / Mechanical Help 1 08-30-2007 10:55 PM
Neutral switch 00R6builder Garage / Mechanical Help 7 06-09-2007 12:51 PM
Throttle Cable Location phatr6 Garage / Mechanical Help 2 07-10-2006 03:04 PM
