Hey guys,
Just wondering if anyone has experience using Woodcraft rearsets for GP shift? After reading a couple of threads, it said that to use GP shift, you need to actually get the PULL QS. Just wanted to confirm if that is correct for any woodcraft users with any brand QS.
the other question is can you use the standard rearset kit for GP shift? If you notice the left side foot peg lever is exactly the same as GP shift, just adding the standard kit on top. the whole placement is the same size and very similar if not the same. Anyone ever run this setup?
pics below...
Standard woodcraft rearset...---note that the bottom whole is the same on the GP shift hole for shift rod placement. Only difference is the lever has the standard placement for the shift rod above.
GP shift rearset---note where the shift rod will go (at the bottom) comparing it to the first photo.
pics below...
