2000 r6 carb clean help. Where to go from here - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 13 (permalink) Old 03-31-2012, 09:51 AM Thread Starter
karlo b's Avatar
Hey guys. So the weather has been cold and I wanted to clean out my carbs.
Im at this stage. How do I take them apart from the engine?
Where do I go from here
karlo b is offline
post #2 of 13 (permalink) Old 03-31-2012, 10:37 AM
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
Re: 2000 r6 carb clean help. Where to go from here
Check out Chief's 02 thread here (lots of pics and write up stuff):
CCS FL #379
Bikez:
01' Champions Limited R6 (retiring from racing) now traded for a truck :-( gonna miss the old girl))
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (Race/Street)
04' Zuma BEAST MODE ENGAGED! 70cc S6 BBK and pipe, 68mph on flat land!
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
90's Blata 40cc water cooled pocket bike (seriously dangerous! 50mph with my 170lb azz.)
99' CR125R (sold)
Shush319 is offline
post #3 of 13 (permalink) Old 04-03-2012, 03:24 AM
I had this issue last week, your sir are at the fun part.
In the picture i attached, you will literally have to go UNDER the carb where the arrows are pointing. There are some VERY small allen wrench bolt about where the circles are. The arrows are where you will enter from with your allen wrench, and the circle is where youll unscrew at. Get a bright light, because they are small. It is a very painful task. But the screws are under it. Took me forever to realize where they were, but im sure you will see them.
-Nix- is offline
post #4 of 13 (permalink) Old 04-03-2012, 05:56 AM Thread Starter
karlo b's Avatar
hey.
yeah i did see some screws in there but was not sure if those will make the carb go loose.
karlo b is offline
post #5 of 13 (permalink) Old 04-03-2012, 05:58 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
hey.
The screws that are easily visible are the sync adjustment screws. It's nearly impossible to see the screws on the boots that are below the carbs
The 02 thread Shush linked is mine and has some helpful pics in there.
ChiefSmokeDawg is offline
post #6 of 13 (permalink) Old 04-03-2012, 06:19 AM
Am I the only one that can't easily see these carb sync adjustments screws? Are they attached to the butterfly valves?
derK is offline
post #7 of 13 (permalink) Old 04-03-2012, 06:32 AM
Parts Pimp
They are in between the carbs on tha shaft that is attached to the buttefly valves. There is a spring on the screw (sort of). Usually there is also a paint mark on them from the factory to show whether it's been adjusted or not.
post #8 of 13 (permalink) Old 04-03-2012, 06:47 AM
I can see them but I can't see the head of the screw unless I rotate the throttle to open the valves a bit. How does Yamaha expect us to sync at idle if you can't even get a screwdriver on without twisting the throttle!?
to the original poster - SORRY for changing subjects for a bit!!
derK is offline
post #9 of 13 (permalink) Old 04-03-2012, 06:59 AM
Parts Pimp
I think that yamaha might make a weird screw driver for this!
post #10 of 13 (permalink) Old 04-03-2012, 08:14 AM Thread Starter
karlo b's Avatar
I will take a look today after work.
karlo b is offline
What's the best oil for a 2000 R6 (the carb) TUFFY Oil and Lubrication 11 02-01-2014 11:36 AM
New R6 owner...can I clean carb jets without removing carbs? WhyZeeEffAreSix General Discussions 6 03-07-2007 10:03 AM
WANTED: 2000 carb intake trumpets Dolts Bike Parts For Sale 0 06-27-2006 07:33 AM
2000 R6 carb help sheetone Exhaust and fuel delivery 4 05-12-2005 09:25 AM
carb question 2000 R6 subzero General Discussions 2 05-01-2005 06:09 AM
