2001 yamaha r6 loses power then dies - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 10 (permalink) Old 04-23-2012, 03:51 PM Thread Starter
Bike: 2001 R6
Images: 1
I was cruising on the highway and then my bike starts to stumble and lose power then it died. It cranked over good. So i check some simple things on the side of the road, gas tank vent is clear, Fuel lines are not kinked. So well i thought i was stuck but ill try to start it again. Left the ignicion on for a bit then started, little stumble then ran fine. drove it back to town and it happened a few more times. It seems to be better at lower speeds like 80 kmh vs 110+. Does anyone have any idea on what it is? Im almost sure its a fuel problem. Im going to take it apart this afternoon.
dtothedog is offline
post #2 of 10 (permalink) Old 04-23-2012, 06:51 PM
Bike: 02 r6
Re: 2001 yamaha r6 loses power then dies
could be a coil going bad, whin you ride for a while at high speed the coil gets hot then shuts down, you can tell by lightly spraying water on each exhaust header to see with one is not hot.
chaka433 is offline
post #3 of 10 (permalink) Old 04-23-2012, 10:27 PM Thread Starter
Bike: 2001 R6
Images: 1
cracked fuel filter, plastic didnt take the heat well by the looks of it. Looked for a steel one couldn't find it at canadian tire so bought a plastic one. I will replace with a steel one as soon as i can get to a real auto store.
post #4 of 10 (permalink) Old 04-24-2012, 06:48 AM
Mario J's Apple Juice
MikeN02's Avatar
Bike: White Raven R6
Did you run out of fuel?
Special Thanks to
for this sig
MikeN02 is offline
post #5 of 10 (permalink) Old 04-24-2012, 07:56 AM
aczaplicki's Avatar
One post above he says cracked fuel filter.
Sent from my HTC Thunderbolt.
aczaplicki is offline
post #6 of 10 (permalink) Old 04-24-2012, 08:12 AM
MikeN02's Avatar
I saw that.
Special Thanks to
for this sig
MikeN02 is offline
post #7 of 10 (permalink) Old 04-24-2012, 09:54 PM Thread Starter
Bike: 2001 R6
Images: 1
well same thing happened again today, worked good for 70 km then same thing happened now. I have ran it till the light goes on but never right out of fuel. Now i am stuck I thought it for sure was the fuel filter
post #8 of 10 (permalink) Old 04-25-2012, 03:33 AM
Loving my R6
Redshift's Avatar
Bike: Y2K R6 | '02 R6 | '06 R6
Images: 2
Garage
Have you checked your fuel pump yet? I have heard of cases where the fuel pump starts to fail and causes intermittent fuel transfer. Also check that all four cylinders are working, seeing that its a 2001 (carb) it might be the diaphragms that are damaged and/or electrical issues (Coil/regulator/stator/earth wire etc).
Need more bikes!!!
Redshift is offline
post #9 of 10 (permalink) Old 04-27-2012, 05:45 PM Thread Starter
Bike: 2001 R6
Images: 1
yea ordered fuel pump... its on back order so who knows when ill get it. we just sinked the carbs. Cant wait to get back on it. On the positive side the weather sucks hear in sask so im not missing any good days
post #10 of 10 (permalink) Old 04-30-2012, 02:42 AM
mean02r6's Avatar
+1 to chaka433. spraying the header with a spray bottle of water will tell you right off the bat what cylinder is running colder or not at all
mean02r6 is offline
power dies at 12k rpm dlyman Garage / Mechanical Help 23 03-09-2012 02:02 PM
2001 R6 - Dies when throttle applied. babalu95 Garage / Mechanical Help 16 04-26-2011 03:06 PM
2001 r6 not starting turns over but loses power?? HD VIDEO included 2001yamaha Garage / Mechanical Help 18 01-26-2011 06:36 PM
2001 R6 complete lack of power at 10000 rpm chinka440 Garage / Mechanical Help 2 09-17-2008 12:14 PM
speedo dies then tach dies then engine! c0de 11 14 46 RRedR6 Garage / Mechanical Help 8 07-17-2008 07:42 PM
