well... it's "work on the r6" time again. - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 32 (permalink) Old 11-01-2012, 04:28 PM
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: stupid ones and a Prius
Re: well... it's "work on the r6" time again.
shush
redisdeadrideblue is offline
post #22 of 32 (permalink) Old 11-01-2012, 06:18 PM
motoman21's Avatar
Bike: '12 R6
I havent changed the bearings yet on my bike but a friend did his (Kawi) and said the barrel or cylinder bearings are the best. Stronger and last longer than the traditional ball bearings. So what do we have in ours, the round ball style?
motoman21 is offline
post #23 of 32 (permalink) Old 11-01-2012, 06:27 PM
Track=Cocaine
R-Silaxin's Avatar
Bike: 06 R-6 Deathraven
Originally Posted by Agg2001 View Post
so i've started my preliminary process...
got my suspension refresh all lined up. thanks tommy! still need to figure out what i'm going to do with the head bearing. :| kinda intimidated - even though i'm great with a wrench.
and changing my fuel management setup - i think. doing the ecu flash paired with the annitori RL qs. IF my bazzaz zfi-qs setup sells.
Sounds great Justin! In for a how-To!
R-Silaxin is offline
post #24 of 32 (permalink) Old 11-01-2012, 06:34 PM
When in doubtThrottle out
mercenary's Avatar
Bike: Always Under Construction
Hopefully the new trackbike doesn't need alot of "winter love" I'm broke.
2009 YZF-R6
2010 Ninja 250
MCRA/CCS#81
Originally Posted by doctorv
I was wrong.
Quote taken 7-16-15 @ 0640CDT
mercenary is offline
post #25 of 32 (permalink) Old 11-02-2012, 12:08 AM
Matchlessmingler's Avatar
Bike: 2006 R6 Team Yamaha Blue
Replacing the bearings is all straight forward until its time to remove the lower bearing race. The manual advocates the use of "specialty" tool in the form of a hammer and a chisel Theres simply no room to pry it out without chipping your steering stem. Some people prefer to cut it with a power tool.
Installation of the lower bearing race can be done with a press. Removing and replacing the upper bearing is simple.
Another couple of links with some info:
FCUK head stem bearings!!!!
Replacing Steering Stem Bearing(s) ??
Good luck!
Some basic R6 outlines for those "digitally challenged" Crayola fans out there
1999 R6 Outline
2003 R6 Outline
2006 R6 Outline
Matchlessmingler is offline
post #26 of 32 (permalink) Old 11-02-2012, 08:26 AM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
I cut my race off (and in doing so scuffed the steering stem) but zfg. It makes no difference performance-wise.
  • What's the difference between an R6 and an R6s? HERE
  • Should I start on a 600 or a 250? HERE
  • How do I ask the forum a question and actually get an answer? HERE
  • Where do I find a map for my Bazzaz? HERE
  • Should I get a 520 kit for MOA POWAH? HERE
  • How does rotating mass work? HERE
pickpocket293 is offline
post #27 of 32 (permalink) Old 11-21-2012, 08:10 PM
iRun
Randomly found the pics I took while replacing my steering head bearing last season.. Dunno if these will be any help to you or not. They basically outlined the steps I went through for the installation... The first few pics are just of the bolts you need to loosen, etc.
ID:	86715   Click image for larger version
ID:	86716   Click image for larger version
ID:	86717   Click image for larger version
ID:	86718   Click image for larger version
ID:	86720   Click image for larger version
ID:	86721   Click image for larger version
ID:	86722   Click image for larger version
ID:	86723   Click image for larger version
ID:	86725   Click image for larger version
post #28 of 32 (permalink) Old 11-21-2012, 08:30 PM
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
Originally Posted by pickpocket293 View Post
Trick to make your life easier-- when you cut off the old bearing, keep it around to use while pounding the new bearing into place (to even out the applied force). Also, put your new bearing under a heat lamp and throw your lower triples in the freezer for an hour. Thank me later. This was not the most fun thing in the world, but it wasn't THAT bad either.
First off, never "pound" the bearing races in...
2) freezer is a waste of time...
3) pop the bearing in the oven at 350-400 for 20 minutes and it will fall into place on the stem...same works for the races.
Tdub is offline
post #29 of 32 (permalink) Old 11-22-2012, 05:11 PM
iRun
Maybe I should've said "tap" instead of "pound".. 2)fair enough. 3) Good call!
post #30 of 32 (permalink) Old 12-10-2012, 01:33 AM
iHak's Avatar
That's an awesome idea for holding up the bike. I think I'll steal that! hhaha
iHak is offline
so, i got rear ended in the truck - "rebuild" time. haha Agg2001 Off Topic Talk 21 11-11-2011 08:48 AM
Ben Spies and Colin Edwards Spending "Quality Time" Together! SpidermanSS Main Page News 27 03-27-2010 01:02 AM
Anyone watch "Pass Time" recently? (9.3 sec Busa) Fever2Ride Off Topic Talk 1 09-25-2008 12:18 PM
screen displays "18", turning signals, brake light, and horn wont work BJTKILLA Garage / Mechanical Help 2 04-14-2008 07:03 AM
JULY 21ST IS "RIDE TO WORK DAY" Mikeeh76 General Discussions 7 07-15-2004 11:18 PM
