well... it's "work on the r6" time again. - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 32 (permalink) Old 08-05-2012, 03:16 PM Thread Starter
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
discovered my head/steering bearing is bad, so i'm going to replace the upper and lower - or whatever a complete replacement is.
any how-to's around? i searched... but you know how that ended. why i'm here now. :|
anyhow, i'm assuming it's pretty straight forward... but don't know if there's any tricks or tips i should know about. also, where the hell do you buy bearings from? haha... never replaced any on my bike. figured all-balls (was looking at bearings for the drz in case they were shot), but don't know for sure.
cliffs: replacing head/steering bearing... get me links to how to and where to buy the parts.
also, i'll be swapping tires to the uk ntecs (giggity), changing fork fluid (pew), changing the oil, and finally (after ~20 months) changing my brake fluid. hahaha.
Agg2001 is offline
post #2 of 32 (permalink) Old 08-05-2012, 03:21 PM
190rwhp......:eek5
jwxfd's Avatar
Bike: 2011 S1000RR, 97 CR500
Send a message via Yahoo to jwxfd
Re: well... it's "work on the r6" time again.
I've never done steering head bearing on a sport bike before, but I'd imagine it's pretty similar to a dirty bike...just gotta put some jack stands under your frame sliders and start dis-assembling.
Buuuut, getting the torque specs would prolly be important, hopefully someone will chime in...probably Melk
Sig courtesy of the man himself: GIjoe007
jwxfd is offline
post #3 of 32 (permalink) Old 08-05-2012, 03:23 PM
Why yes I don't!!!!!!!!!!
TurboBlew's Avatar
Bike: 2007 In Heaven
the all balls timken style setup is really nice. Hardest part is cutting the old race off the triple. (easily done with a dremel and steady hand)
Big screwdriver & mallet to punch out the old races from the neck.
TurboBlew is offline
post #4 of 32 (permalink) Old 08-05-2012, 03:23 PM Thread Starter
Agg2001's Avatar
i didn't even think about the service manual. you said "torque specs" and i remembered i have one. haha. i'll check that, but i'm assuming there's a better way and FOR SURE a good place to get the parts from. unless OEM is the way to go.
Agg2001 is offline
post #5 of 32 (permalink) Old 08-05-2012, 03:24 PM
Lifetime Premium
Miller'sR6's Avatar
Bike: 2012 Yamaha Blue R6
I have done it on an old Gs550 and it was fairly simple. Just make sure you don't over tighten the jam nuts.
Miller'sR6 is offline
post #6 of 32 (permalink) Old 08-05-2012, 03:45 PM
Eric10301's Avatar
Bike: 08 R6 Track Bike
It's pretty easy and self explanatory. The only part that I had to do anything special was creating something to tighten the weird nut.
Eric10301 is offline
post #7 of 32 (permalink) Old 08-05-2012, 03:51 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
That's how I've done it. Used a threaded rod with a washer and nut on each end to press the new ones in. Well thats how I did it on the 250, they were notorious for wearing steering stem bearings.
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #8 of 32 (permalink) Old 08-05-2012, 03:52 PM
Lifetime Premium
Miller'sR6's Avatar
I just used a hammer and a flat head.
post #9 of 32 (permalink) Old 10-21-2012, 01:05 PM Thread Starter
Agg2001's Avatar
Part have started wing purchased - long with a few others.
(excuse typos, as this was a mobile posting)
Agg2001 is offline
post #10 of 32 (permalink) Old 10-21-2012, 01:33 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
Trick to make your life easier-- when you cut off the old bearing, keep it around to use while pounding the new bearing into place (to even out the applied force). Also, put your new bearing under a heat lamp and throw your lower triples in the freezer for an hour. Thank me later. This was not the most fun thing in the world, but it wasn't THAT bad either.
pickpocket293 is offline
Ben Spies and Colin Edwards Spending "Quality Time" Together! SpidermanSS Main Page News 27 03-27-2010 12:02 AM
screen displays "18", turning signals, brake light, and horn wont work BJTKILLA Garage / Mechanical Help 2 04-14-2008 06:03 AM
JULY 21ST IS "RIDE TO WORK DAY" Mikeeh76 General Discussions 7 07-15-2004 10:18 PM
