07' Integrated tail light.. - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 9 (permalink) Old 10-11-2012, 07:25 AM Thread Starter
Bike: 07' R6
Images: 2
So after much contemplation I'm going to install an integrated tail light. Originally I was against the idea just due to the fact that I wanted it as obvious as possibly to people on the road which direction I was turning, so I bit the bullet and kept that hideous rear fender on. I can't stand looking at it anymore lol. I'm haven't done any mods whatsoever yet and this would be my first. How easy is the install? I've heard that on the 06-07's you have to completely take the rear apart?? Sounds like a major pita.. Also, any brand recommendations? Motodynamic, Clear Alternatives etc? I'm not sure if I want the standard signal or the sequential either.. Thanks!
McG241 is offline
post #2 of 9 (permalink) Old 10-11-2012, 08:32 AM
FairladyZ33
Labelworkshop75's Avatar
Bike: 2006 50th R6
Re: 07' Integrated tail light..
Get the Motordynamic. Takes 15 min to install. Very easy. Comes with full instructions
Labelworkshop75 is offline
post #3 of 9 (permalink) Old 10-11-2012, 05:44 PM Thread Starter
Bike: 07' R6
Images: 2
Thanks, I think that seems like the best option both quality and pricewise!
McG241 is offline
post #4 of 9 (permalink) Old 11-07-2012, 04:46 AM Thread Starter
Bike: 07' R6
Images: 2
Does anyone know if I'll be required to buy an aftermarket relay for the motodynamic to match the factory flash rate?
McG241 is offline
post #5 of 9 (permalink) Old 11-07-2012, 06:58 AM Thread Starter
Bike: 07' R6
Images: 2
Edit: I do not have led front signals, just the stockers. In the installation instructions on their site it says you should get a resistor/relay if you have front led's. So does that mean that if I have stock fronts that the rear integrated should flash at a normal rate? It should be here tomorrow, just to figure out if I should order a relay now before I attempt to install it.
McG241 is offline
post #6 of 9 (permalink) Old 11-07-2012, 09:41 AM
Laugh now, cry later
Thecca's Avatar
Bike: 03 R6, 04 Z1000
Correct me if I'm wrong, but I think resistor are built-in in the MD kits.
Current bike : Z1000
Shortened oem slip-on, K&N filter and PC3, rizoma levers, sprocket kit
Old bike : YZF-R6
MJS shorty slip-on, K&N filter
Originally Posted by Aj-Agwa View Post
why when i put the straight pipe on a i rev it to like 5 or greater RPM the bike turns off??
Dafuq?
Thecca is offline
post #7 of 9 (permalink) Old 11-07-2012, 01:56 PM Thread Starter
Bike: 07' R6
Images: 2
I finally got a response from MD, they said as long as you have stock front signals no resistor/relay is required.
McG241 is offline
post #8 of 9 (permalink) Old 11-07-2012, 02:20 PM
slouche
KBkilla's Avatar
Bike: 2012 R6
I went with the Motodynamic as well for my 12. Install was not hard at all, but did take some time as I like to go slow and keep track of what went where. You won't need the resistors with the stock front turn signals. You also won't need them for aftermarket signals unless you want the same flash rate. I prefer the faster flashing, so I didn't install a resistor on mine. Good luck.
KBkilla is offline
post #9 of 9 (permalink) Old 11-07-2012, 03:15 PM
lolerbaiting
elbaldwino's Avatar
Bike: 2007 YZF-R6
+1 for MD. I used a relay (flushies up front). This has been beaten to death here.
Install was easy except around parts of the tail.
"I come in peace, I didn't bring artillery. But I am pleading with you with tears in my eyes: If you **** with me, I'll kill you all"- Gen James Mattis
How to install Shermoto levers
elbaldwino is offline
FS: Integrated Tail Light, Flush Mounts, License plate light JTolles Bike Parts For Sale 11 03-21-2012 10:11 AM
integrated tail light air226rider Appearance and Exterior Mods 7 03-11-2011 05:15 PM
led integrated tail light? R6AAC General Discussions 18 08-22-2008 08:44 PM
Integrated tail light help kin Appearance and Exterior Mods 3 07-16-2008 03:33 PM
Integrated Tail light for 06 R6 06blueR6 Appearance and Exterior Mods 0 04-11-2006 08:18 PM
