Valve Adjustment - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 156 (permalink) Old 10-11-2012, 06:33 PM
"The Dude abides .. "
MELK-MAN's Avatar
Re: Valve Adjustment
you won't get carbon build up on the intakes.. only the exhaust (air/fuel in and then the intake valve is closed when it goes "bang" and when the exst valves opens), but the bike DOES look amazing. Awesome upkeep. That seat looks like you could take a good long ride and not have your butt fall asleep.
MELK-MAN is offline
post #22 of 156 (permalink) Old 10-11-2012, 07:08 PM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
Well at 16k miles after only using YamaLube (I had no idea it was the worst oil on the market) I had carbon build up on the intake valves, I switched over to Amsoil and by the next oil change the valves were crystal clean. AND YES I KNOW it should not really effect the intake valves since they are being sprayed with fuel the entire time and should not ever come in contact with engine oil (but the crankcase does breath through the airbox), but I have honestly refueled at the same Exxon near my house every of the time (I have to refuel at different places away from home on long trips, obviously), but I can't realy quantify it but it happened. And yes the seat is AWESOME.
Modifications- PCV w/ Autotune, LCD, & Quick Shifter, GraveSport Slip-on, Slide Stops, K&N filter, Factory Pro +4 Ignition rotor, SuperFlare Velocity Stacks, AGG block off plates, Fren Tubo Type 4's, EBC HH Brake pads, 520 Driven Sprockets & EK ZZZ Chain, Penske 8987 shock, 07 USD Forks and Brakes in 05 Triples, ASV C5 Levers, Scotts Steering Damper, GYTR Carbon Chain Guard, GYTR Carbon Toe Guard, Canadian GYTR Frame Sliders, GYTR Carbon Tank Pad, BST Carbon Rear Fender, Competition Werks Fender Eliminator, UFO Integrated Tail Light, Metzler M5 D-Spec Tyres, Gilles Chain Adjusters & Lifters, Gilles Rear-sets, Powder Coated Passenger Rear-sets, GYTR Seat Cowl, SaddleMen Seat, Irate Customs Grill, Gregg's Flush Mount Signals, DDM 5K H.I.D.'s, Integrated Beltronics 985, and
Phrozen is offline
post #23 of 156 (permalink) Old 10-11-2012, 07:34 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
A bike without any imperfections is just asking for a slide, if you ask me.
pickpocket293 is offline
post #24 of 156 (permalink) Old 10-11-2012, 08:25 PM
Stunt Rider
ridick_bowen's Avatar
Bike: R6/R1 Hybrid
My bike has got character.
R6/R1 hybrid
ridick_bowen is offline
post #25 of 156 (permalink) Old 10-11-2012, 09:11 PM
MELK-MAN's Avatar
i'm not superstitious.. yet when i have race bodywork painted, or get a new set of leathers or a helmet, i put a little scratch on it
MELK-MAN is offline
post #26 of 156 (permalink) Old 10-11-2012, 09:44 PM Thread Starter
Box Boy @ Woodcraft
Jason P.'s Avatar
checking valve clearance is VERY easy.. adjusting valves is another story entirely. I would get a quote to CHECK valves. The 3rd gen valves are coated titanium valves. The hard coat just doesn't wear for a very long time. Once it wears off though, and the soft TI (soft compared to stainless steel) is exposed to the valve seats, the recess up into the valve pocket pretty fast, your clearance shrinks, and you get lower compression numbers. That leads to hard starts, and loss of power.
Again.. CHECKING clearance is super easy. Pull the tank and airbox outa the way. Get all the plug wires and coils out, the valve cover will come out, and then remove the timing chain/ignition cover. Rotate the crank with teh 12mm bolt to get the intake cam lobes pointed back for each pair you check.. and the exst. lobes pointing forward (all level with the head angle). Slide the feeler gauge under each lobe!
That's it! if you can't get the spec feeler in there, they are out of spec. If you can't get ANY feeler gauge in there.. the clearance is close to or zeroed out.
spark plugs every other oil change?? wow.. LOL .. benefit of that is his plugs should never get seized in the head
thnks for the info! i have a friend with a kawi and he is wanting to tackle his valves. im thinking of hanging out and watching what happens. if all goes well then i will check mines out before i decide if a valve adjust is needed at that time.
plugs first. then i shall worry bout this valve jobbs
Jason P. is offline
post #27 of 156 (permalink) Old 10-11-2012, 09:56 PM
Shawn3210's Avatar
Bike: 2014 R6
how often do you track or race only guys do it? I have one full race season on my bike but I'm only at like 4000 miles.
CVMA #143
instagram shawn3210
Shawn3210 is offline
post #28 of 156 (permalink) Old 10-11-2012, 10:01 PM
iRun
My bike has 5800 miles (all but 1000 of those are on the track only) and I will not be doing a valve check until at least 20k miles (if it survives that long). These bikes were DESIGNED to be ridden hard at the track. That's what they're made for.
post #29 of 156 (permalink) Old 10-11-2012, 10:03 PM
Will work for track time
redwood650's Avatar
Bike: An orange one
Do it yourself. I have a half write up that I never completed. Its really not that hard to check them especially if you have a manual.
redwood650 is offline
post #30 of 156 (permalink) Old 10-11-2012, 10:18 PM Thread Starter
Box Boy @ Woodcraft
Jason P.'s Avatar
i have about 8 track day times on mines and rode about 20,000 since i got her back in 3/10. will do the check myself but if it needs adjusting then i am sourcing a reputable shop.
Jason P. is offline
Valve adjustment mr.zeetser General Discussions 2 08-31-2011 07:56 AM
Valve Adjustment? Polishguy712 Garage / Mechanical Help 0 07-19-2011 04:28 PM
How Can You Tell If You Need Valve Shims When Doing A Valve Adjustment? blk600cc General Discussions 12 05-10-2009 10:20 PM
How Much Would A Valve Adjustment Go For? blk600cc General Discussions 12 04-07-2009 06:39 PM
yzf valve adjustment flynlow3 How To's... 1 07-31-2006 08:01 PM
