speed problems... then hesitation - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 19 (permalink) Old 11-17-2012, 10:47 AM
Black On Black Is Back
Silversun262's Avatar
Did you get it fixed? I'm having a similar issue. Just started yesterday out nowhere.
Silversun262 is offline
post #12 of 19 (permalink) Old 11-17-2012, 12:09 PM Thread Starter
Re: speed problems... then hesitation
Ya man... I changed all the ignition coils and now runs just like new !! I turned the bike on for 2 or 3 minutes and then sprayed the headers with water. One pipe didn't evaporate the water so one cylinder wasn't firing at all. Checked the olms on the ignition coils and that one was way off spec. The other 3 were off spec also. So I changed all 4 and now all better
tekk220 is offline
post #13 of 19 (permalink) Old 11-17-2012, 12:22 PM
Werd. Looks like a bike fix night if I can get my hands on some new coils today. Effers ain't cheap.
post #14 of 19 (permalink) Old 11-17-2012, 12:25 PM Thread Starter
I got mine online from babbits.. cheapest I found them for... And it was still expensive lol
tekk220 is offline
post #15 of 19 (permalink) Old 11-18-2012, 07:26 PM
Tested mine today. Seem to be in spec, but not consistent. #3 primary is much higher then the others at .4, so I'm thinking that one may be the offender. Any input from anyone? Sorry to highjack, but is still on topic
Coils
1- 5.50. .2
2- 5.06. .2
3- 5.35. .4
4- 5.36. .2
post #16 of 19 (permalink) Old 11-19-2012, 12:26 AM Thread Starter
Hmmm... Turn the bike on for a few minutes and spray the headers with water using a spray bottle... See if one doesn't evaporate water at the same rate as the others. If the same header with the odd coil evaporates slower than the others then you have 2 things pointing at getting a new coil.
tekk220 is offline
post #17 of 19 (permalink) Old 11-19-2012, 09:59 AM
Yeah sorry, for got to say what I have done.
1 replaced spark plugs
2. all header pipes hot (equal evaporation)
3. cleanedTPS
4. new gas
Mods
1 PC3 with new map (considering loading the old one back in)
2. slide stops
3. smog block off
4. devil high mount
5. 31K miles
6. KN
post #18 of 19 (permalink) Old 11-19-2012, 12:42 PM Thread Starter
3. cleanedTPS
4. new gas
i did all the same first as well.. when my bike was running bad but not horrible it was still getting spark and all header tubes were equal. it was when 1 ign coil stopped working all together that the header tube stayed cold and the bike ran like complete shit. i would say change the 1 coil... cheapest option left and might fix it. also.... did you get your valves checked yet? you are supposed to at around 24k miles.
tekk220 is offline
post #19 of 19 (permalink) Old 11-19-2012, 03:45 PM
Did valves at about 20K. Gonna replace all 4. Found a deal on 4 used. we'll see.
MY00 low speed hesitation problem Tucker_82 Garage / Mechanical Help 6 08-25-2012 06:27 AM
Any problems with hesitation at 7,500 rpms until 8,200? CollinR6 Exhaust and fuel delivery 1 07-21-2009 07:17 PM
2 problems... hesitation and tranny noise joker1254 Garage / Mechanical Help 0 09-09-2007 01:34 PM
speed problems JonesSoda87 Garage / Mechanical Help 4 06-15-2007 10:17 AM
06 speed sensor problems? motox_315 General Discussions 0 05-17-2007 01:23 PM
