cam chain tensioner - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 10 (permalink) Old 11-03-2012, 12:12 PM Thread Starter
What Lateral G's?
cam chain tensioner
Quick note to everyone rebuilding/replacing cams or engines. After the rebuild i *assumed* that you could put the tensioner back in. Follow the manual...lol...I chewed through a chain guide. Haven't broke the engine in yet so I'm hoping that the residual plastic should wash into the pan before i need to change the oil after the rebuild.
Racing R6's with CORN!
South Dakota State FSAE
Engine/Drivetrain '12-'13
Electrical/Das '11-'13
Team Lead Eng. '13
jlangholzj is offline
post #2 of 10 (permalink) Old 11-03-2012, 12:18 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
You can put the cct back in...
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #3 of 10 (permalink) Old 11-03-2012, 12:19 PM
Suk it, Lee
Ryan5544's Avatar
Re: cam chain tensioner
I'm confused..
Ryan5544 is offline
post #4 of 10 (permalink) Old 11-03-2012, 12:20 PM
pin it to win it
bryan j's Avatar
Originally Posted by Ryan5544 View Post
I'm confused..
Sounds like he took the cct out then when he put it back in, somehow it ate the chain guide
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #5 of 10 (permalink) Old 11-03-2012, 12:34 PM Thread Starter
What Lateral G's?
bingo.
rebuilt the engine
timed the cams
re-installed the tensioner.
You have to put a little clip on a peg on the tensioner piston:
Didn't do this properly
I'm assuming the residual pressure in the tensioner was too much and as a result my plastic guide on the tensioner got ate to shit.
Like i stated earlier, haven't properly broke the engine in yet, so I'm hoping the plastic particles will wash into the pan. Once I change oil after break-in I'll flush it out from the head and get the rest out.
Team Lead Eng. '13
post #6 of 10 (permalink) Old 11-03-2012, 12:47 PM
Suk it, Lee
Ryan5544's Avatar
Ah yes. I see now.
You know, I really wish someone would do a real good write up on shimming valves, and cct install.
What that has to do with anything, I don't know.
Ryan5544 is offline
post #7 of 10 (permalink) Old 11-03-2012, 01:05 PM
pin it to win it
bryan j's Avatar
Ah yes. I see now.
I keep meaning to do a, write up
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #8 of 10 (permalink) Old 11-03-2012, 01:06 PM
Suk it, Lee
Ryan5544's Avatar
Do it! I'm tearing into mine reasonably soon, and I can't say how much a nice guide to go by, would make life so much easier.
Ryan5544 is offline
post #9 of 10 (permalink) Old 11-03-2012, 01:20 PM
pin it to win it
bryan j's Avatar
alright, when I get a chance to use sometimes computer ill make one.
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #10 of 10 (permalink) Old 11-03-2012, 04:20 PM Thread Starter
What Lateral G's?
to get back on subject
Installed the tensioner per factory spec. Now I think i just need to get a new mechanical....When its installed per the manual, you can hear quite a bit of chatter and it doesn't run the greatest. When i back the mounting bolts out a bit to click it down tighter, its too tight (you can hear a whiring noise when cranking) but it runs great and there's no chatter.
Team Lead Eng. '13
changing chain chain tensioner pod1 General Discussions 2 08-10-2012 09:14 AM
Cam Chain Tensioner 2K5 tictoc Garage / Mechanical Help 5 04-08-2010 08:17 AM
cam chain tensioner ?s #12 Garage / Mechanical Help 8 10-07-2009 06:34 PM
CAM Chain TENSIONER... NucleusZ Garage / Mechanical Help 1 07-09-2007 01:25 PM
