need help, sluggish in 1st gear - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 2 (permalink) Old 11-04-2012, 04:57 PM Thread Starter
I got on my 04 R6 to ride to work, once on it I noticed it was sluggish and unresponsive in 1st gear and partly in 2nd. The rest of the gears are fine. Need help please.
cfreyhof93 is offline
post #2 of 2 (permalink) Old 11-04-2012, 06:53 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Re: need help, sluggish in 1st gear
Sounds like a dirty or bad TPS. Was the bike fully warmed up? Go into diag mode and check the stored codes (read how in your service manual). You can do a TPS test while you're in there too, twist it slow and see if the number jumps around, and make sure the min and max numbers are within spec.
-Jamie M.
toysareforboys is offline
My R6 seems sluggish killn_hajis General Discussions 9 07-14-2011 03:59 AM
R6 seems sluggish Peridious Garage / Mechanical Help 4 04-29-2008 08:54 AM
sluggish 03 R6 r6reksta Garage / Mechanical Help 2 09-18-2006 03:28 PM
sluggish low end?? jscstar13 Garage / Mechanical Help 11 07-24-2006 11:18 AM
sluggish low end?? jscstar13 Garage / Mechanical Help 0 07-22-2006 06:43 PM
