Before I touch anything! - Engine gurus - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
post #31 of 48 (permalink) Old 11-05-2012, 09:29 PM
m3lover2
Aleeex's Avatar
Bike: Trek Fuel 90
Or chain is binding somewhere
Aleeex is offline
post #32 of 48 (permalink) Old 11-05-2012, 09:40 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Either piston is hitting the valves or you're feeling the compression (if the plugs are still in)
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #33 of 48 (permalink) Old 11-06-2012, 12:12 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
Re: Before I touch anything! - Engine gurus
Ya... Fair enough
Well, I think tonight I'll pull the head off, and see what's going on.
Before, when I first started it, it would knock real hard, and then stop, so, I'm assuming there's more to this issue..
Ryan5544 is offline
post #34 of 48 (permalink) Old 11-06-2012, 12:37 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
Ever have that deep feeling of regret, and knowing, '' I shouldn't have even touched the fcuking thing'' feeling?
I has that now..
But, probably a good idea I did take it out, before something went horribly wrong.
Ryan5544 is offline
post #35 of 48 (permalink) Old 11-06-2012, 12:42 PM
pin it to win it
bryan j's Avatar
Its simple you're just over thinking it.
retime it and take you're time. Make sure all the marks are aligned and you're good.
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #36 of 48 (permalink) Old 11-06-2012, 12:44 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
Out of curiosity, do you think it's possible I can't turn it when It's all bolted down, because it's in gear?
I'm at work, or I'd try..
I feel like I'd know if there was a bent valve, is the thing. You may be right, just over thinking it. It worked just fine before, and I haven't touched anything. Should be fine.. Friend came over last night, and said the same.
The valve clearances are way out to lunch, so that could have been the knocking noise.
Ryan5544 is offline
post #37 of 48 (permalink) Old 11-06-2012, 12:48 PM
pin it to win it
bryan j's Avatar
I has that now..
Oh ive had that feeling to often. When I was 13 I decided id rebuild the too end in my 250. I reused a 25 cent cir clip instead of getting new ones. That clip cost me almost 2k in the long run. Destroyed my engine
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #38 of 48 (permalink) Old 11-06-2012, 01:05 PM
pin it to win it
bryan j's Avatar
Put it in neutral, pull the plugs out, and take the valve cover and ignition cover off.
It should spin easy. if it doesn't your timing is prly off.
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #39 of 48 (permalink) Old 11-06-2012, 04:26 PM
"The Dude abides .. "
MELK-MAN's Avatar
even if you DO take the head off, if you can't set the timing on the 2 cams properly, you're fu ck ed.. just later than sooner this time. and yes, if it's in gear and you turn the motor over at the crank with the 12mm socket, the rear wheel will just spin. If it's not turning over something is wrong. you need a manual. cap bolts for the cams need torqued down in sequence. And i suggest not pulling the head off just yet.. if you do, get a new head gasket before hand and those head bolts FOR SURE need torqued down properly.
MELK-MAN is offline
post #40 of 48 (permalink) Old 11-07-2012, 06:49 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
Thank you everyone for your help!
Really appreciate it!
Turns out... I'm an idiot..
Took it out of gear, and spins perfect now! Timing is set dead on, and all is well!!
Happier then a pig in shit.
Ryan5544 is offline
Need Help from Electrical Gurus AlwaysSomething General Discussions 7 07-05-2010 09:56 PM
Question for engine gurus Fubba General Discussions 2 07-06-2009 06:41 PM
paint gurus please look alecseborp Appearance and Exterior Mods 11 05-13-2008 05:18 PM
Photoshop gurus CANDYR6-S Appearance and Exterior Mods 3 08-18-2007 10:58 PM
