Before I touch anything! - Engine gurus - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 48 (permalink) Old 11-04-2012, 08:21 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
So, got it peeled apart, to check the valve situation out--
I took the CCT out, before popping the valve cover (see now I shouldn't have).
Now, this is what I'm looking at. I could be stressing over nothing, but before I touch anything, looking for some guidance.
As you can see, the chain is off one of the cams, that's how it was sitting when I pulled the cover.
Now, when I stick my finger in the cct hole, I can take the slack off, but, not enough to pull it so it's tight, and locked in. But, when I let the slack go, it falls nicely into place. (see photos)
What do you suppose I do here. Is this something that will pull together when I put the new cct (manual) in, if you understand what I'm saying.. Or, is this something I need to deal with now?
Any more info I can provide, to help you answer, just ask! Am just being cautious, not touching anything, before I know exactly what I have on my hands. I'm not experienced with anything inside the engine, just know enough to mark, and put everything back exactly the way it came out, and the steps for checking my clearance. Everything else is a new language.
Thank you for any help!!
Here's what's going on:
Something tells me I either need to crank the motor, to make it fall in place, or, when I put the tension on the actual tensioner, it will pull it into place, but I'd rather not guess.
What do ya figure?!
Thanks.
Ryan5544 is offline
post #2 of 48 (permalink) Old 11-04-2012, 08:24 PM
m3lover2
Aleeex's Avatar
Bike: Trek Fuel 90
You can always text a russian
Aleeex is offline
post #3 of 48 (permalink) Old 11-04-2012, 08:26 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
Text sent.
Ryan5544 is offline
post #4 of 48 (permalink) Old 11-04-2012, 08:38 PM
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
I took the timing cover off and just held tension on the chain as I tightened it. when you are tightening the cams down watch the chain to see if its coming off the sprocket. If it is tighten the opposite side of what you're doing
Go fast parts:
, Shorai battery.
Body:
Support the forum Vendors
bryan j is offline
post #5 of 48 (permalink) Old 11-04-2012, 08:49 PM Thread Starter
Suk it, Lee
Ryan5544's Avatar
Ok. That makes sense.
But, when you had it apart, was it sitting on top of the cam like that?
And as you did tighten the chain down, did it pull into place?
Like, I feel like it would turn the motor clockwise ever so slightly, that it would drop on.
Ryan5544 is offline
post #6 of 48 (permalink) Old 11-04-2012, 09:19 PM
pin it to win it
bryan j's Avatar
AS Long as I kept tension on it and tightened the cams down it fell into place.
Go fast parts:
, Shorai battery.
Body:
bryan j is offline
post #7 of 48 (permalink) Old 11-04-2012, 09:26 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
Re: Before I touch anything! - Engine gurus
Holy shit, you took the motor out?
I'm scurred.
pickpocket293 is offline
post #8 of 48 (permalink) Old 11-04-2012, 10:06 PM
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
I see you have GSX-R in your "bike" section. What is the year and model? You see the line on the front cam sprocket? That is the timing/alignment mark. That is suppose to be even with the head with no.1 cyl @ TDC. There is on on the rear cam sprocket too. Crank and both cams must be in the proper place or you fooked!
You can find the manual for your bike from here:
Look for the "camshaft" section of the "engine assembly" section something like this (from 01-03 models, different years is different but fairly similar procedure):
CCS FL #379
Bikez:
01' Champions Limited R6 (retiring from racing) now traded for a truck :-( gonna miss the old girl))
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (Race/Street)
04' Zuma BEAST MODE ENGAGED! 70cc S6 BBK and pipe, 68mph on flat land!
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
90's Blata 40cc water cooled pocket bike (seriously dangerous! 50mph with my 170lb azz.)
99' CR125R (sold)
Shush319 is offline
post #9 of 48 (permalink) Old 11-04-2012, 10:10 PM
iRun
He's actually got an R6, but his "gixxer" thing is him being a smart ass.. I believe.
post #10 of 48 (permalink) Old 11-04-2012, 10:16 PM
Shush319's Avatar
Bike: listed in sig
Good way for me to waist my 1,000th post......
Either way, cam alignment procedure is very similar between models. Just check the shop manual OP.
03-04 r6:
CCS FL #379
Bikez:
02' R1 (sold)
01' XR70R (sold)
99' CR125R (sold)
Shush319 is offline
Need Help from Electrical Gurus AlwaysSomething General Discussions 7 07-05-2010 09:56 PM
Question for engine gurus Fubba General Discussions 2 07-06-2009 06:41 PM
paint gurus please look alecseborp Appearance and Exterior Mods 11 05-13-2008 05:18 PM
Photoshop gurus CANDYR6-S Appearance and Exterior Mods 3 08-18-2007 10:58 PM
