HELP!cant figure it out.. idle/vaccum/fuel ? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 11-07-2012, 03:57 PM Thread Starter
Bike: 07 r6s
Angry HELP!cant figure it out.. idle/vaccum/fuel ?
So check this out!!!!!!
I have a 07 r6s with 05 fairings... So i wnet to change my fairings with the new ones i bought.. so i also painted my tank.. welllllll... i took the air box off in the mean time waiting for the paint to dry... and shot carb cleaner into the throttle body ... to spruce it up.. it was idling ruff! thought it might help.. so after insatlling everything back fairings and all i go to ride and it is running on 3 cyclinders! so i exam and find which one is not running by puttung water on ehxaust pipes.. so i change all spark plugs and take fuel injectors off to exsm them.. all is well.. so i take the cyclinders injector that wasnt running and put into another cyclinder... to see if it is faulty... cauz that would cause the cyclinder it is in now not to run.. also i changed the park plugs ..so put it all back together... all 4 cyclinders are running good and strong.. BUT>>>>>> now mi idle is sitting at 3,500/3,600 rpms...wtf? i exam idle screw... i unscrew it to were it is not even touchn the throttle... still 3,600 rpms... i now suspect a vaccum leak... so i spray carb cleaner around and it idled higher bearly i mean just bearly around the throttle boddy boots that conect to the mootor.. so i take off the throttle body and inspect boots.. they r perfect.. re install throttle body and connect everyhting.. still 3,600... wtf i am stumped... PLEASE HELP ME
also i sprayed so carb cleaner around again after i put it back together.. AGAIN.. and in the front by the spark plugs there was a section that i sprayed by the 2nd plug (2nd plug from the left if u were sitting on the bike) and it idle bearly i mean just bearly again higher.. wtf could be up there by the plugs that might be causing a vaccum leak if at all a vaccum leak is the problem???? plzzzzzz help me...... plz
thanks guys
kipmedford is offline
post #2 of 6 (permalink) Old 11-07-2012, 04:10 PM
1 wheel R6
OCR6714's Avatar
Bike: 05 R6, 07 R6
U can use a smoker to search for the leak or under the rear seat is a vacuum diagram
Sent from my iPhone using
2005 R6
Team Yamaha Blue
OCR6714 is offline
post #3 of 6 (permalink) Old 11-07-2012, 04:19 PM Thread Starter
Bike: 07 r6s
Re: HELP!cant figure it out.. idle/vaccum/fuel ?
thanks.. im gonna go look... but i have gone over it several times.. once more will not hurt tho... u think it could be ecu related or something?
post #4 of 6 (permalink) Old 11-07-2012, 04:21 PM Thread Starter
Bike: 07 r6s
just looked.. all connected properly? im stumped
post #5 of 6 (permalink) Old 11-07-2012, 05:09 PM
1 wheel R6
OCR6714's Avatar
Bike: 05 R6, 07 R6
Is your throttle snapping all the way back? Maybe it's stuck in an open position?
Don't know how mechanically incline you are maybe take the air filter out and see if when the bike is on and idling if the throttle bodies are opened way up?
These are just guesses so if u fcuk it up don't blame me lol
Throttle sync issue?
2005 R6
Team Yamaha Blue
OCR6714 is offline
post #6 of 6 (permalink) Old 11-08-2012, 12:34 AM Thread Starter
Bike: 07 r6s
i figured it out..... i took all the fuel injectors off again... and put it back together slow and steedy... she worked... when i started her up she reved real fast and then down to normal idle but she fluctuates sometimes now like the idle will be at 1,250 rpm and then go to 2,00 rpm... and if i try to adjust the idle with the right side screw it will stay there or jump straight to and over 2,200.. i cant find no in between.. and its hard to get a good idle..i have to play with it every time i ride... wtf.. **** it at least its mobile
cant figure this out flameoutgarrett Garage / Mechanical Help 5 03-27-2015 09:54 PM
2002 R6 -- Found this while removing some stuff off the bike (open vaccum line?) jnicola Exhaust and fuel delivery 3 03-31-2012 10:19 AM
06 R6s Idle/fuel issue Frasier14 Exhaust and fuel delivery 4 03-08-2012 07:31 PM
04 idle screw doesn't change the idle geeniusatwurk Garage / Mechanical Help 4 01-15-2010 10:05 AM
