Wiring issue, and turn signals. - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 2 (permalink) Old 11-12-2012, 06:04 AM Thread Starter
I have an 02 R6, first off...when I bought it the guy said that he bought it without turn signals on the front, I bought turn signals for it, but the wires were no where to be found to plug them in. Anyone know what color wires I should be looking for, and perhaps where they begin? Also, without front turn signals, will it cause both of my rear lights to flash when hitting the turn signal switch? Another question, I just got my bike out of the shop from getting valves adjusted, plugs, carbs synced, etc etc. I get it back, and my Rpm gauges isnt work, it's very jumpy, it goes up to 4 k, then up to my actual rpms, then back to zero constantly, And my temperature gauge seems to be off quite a bit. Any help with this issue would be appreciated.
J.F.Walker79 is offline
post #2 of 2 (permalink) Old 11-12-2012, 05:48 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Re: Wiring issue, and turn signals.
I would pick up a new wiring harness if you want to be sure everything is and will work properly in the future.
If you want your rear signals to work properly without front signals connected pick up a digital flasher relay and you'll be set.
Good luck.
-Jamie M.
toysareforboys is offline
WTB: 2006 R6S mirrors, rear turn signal assembly & front turn signals r6sport Bikes + Parts + Gear Wanted 3 03-08-2012 09:16 AM
Integrated turn signals with mounted signals MikeMag102 Appearance and Exterior Mods 7 10-11-2011 06:07 AM
Wiring for turn signals, where are they located? zeedarkjster Garage / Mechanical Help 6 05-18-2010 03:40 PM
WTB oem turn signals, and rear turn signal licenses plate set up importchyno Bike Parts For Sale 0 07-22-2008 05:46 PM
VFX Pivot Fender Eliminator - Wiring turn signals? Riceboy369 General Discussions 0 01-24-2008 02:09 PM
