'07 - O2 sensor with PC ? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 11-20-2012, 06:23 PM Thread Starter
Tori's Avatar
Bike: 2007 R6
Hi guys, quick question.
I've got a track only '07 R6 w/ Power Commander, and full Graves exhaust. Currently there is an O2 sensor threaded into the exhaust. After removing the tank for some other work, i notice that it is unplugged.
Should it be unplugged with the Graves and proper PC setting ?
Also, i am putting the stock exhaust on temporarily for a trip to Laguna in a couple weeks. Should i run the O2 with the stock exhaust ? and what about the valve thingy in the muffler ? Leave that active or not ?
I was told by some Yamaha guys to leave the actuator unplugged so the valve stayed open, and just leave my PC setting the same as with the Graves system.
Thoughts ?
Tori is offline
post #2 of 7 (permalink) Old 11-20-2012, 07:10 PM
zero389's Avatar
Bike: 07 R6
Re: '07 - O2 sensor with PC ?
I leave my O2 unplugged with my akra. I feel it would kind of try to work against the PC if its left plugged in.
If your putting your stock exhaust back on I would re-connect the exup valve and the O2 sensor, and if your doing that you may as well put a zero map on the PC.
Why are you putting the stock exhaust back on anyway?
zero389 is offline
post #3 of 7 (permalink) Old 11-20-2012, 08:02 PM Thread Starter
Tori's Avatar
Bike: 2007 R6
Laguna Seca. Going there for a trackday. They have a sound limit of only 92 db, so you gotta run your stock exh.
Tori is offline
post #4 of 7 (permalink) Old 11-21-2012, 07:44 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
+1 to running a zero map. Otherwise you'll be running rich and fat and the bike could feel tame, boggy etc.
The 02 sensor really only makes corrections within a narrow range, at lower RPM and lower throttle %'s. It will do no good on the track.
Hopefully you have the OEM air filter with restrictor, cause the intake noise of the bike without can come close to the limit!
If you're running the OEM can, I'd connect the EXUP and all that to let it do it's job. Take advantage of the low end power it helps create!
ChiefSmokeDawg is offline
post #5 of 7 (permalink) Old 11-21-2012, 04:09 PM
lucky bastard, sorry, just have to vent cause i live in WV and it would be a pretty far drive there. but on the other hand, im only 6 1/2 hours away from deals gap.
also please take as much video as you can. never hurts to show what most people cant do.
Mudkickr is offline
post #6 of 7 (permalink) Old 03-03-2013, 04:35 AM
Chicken Stripper
Gigag04's Avatar
Bike: 2006 R6 Track
I have a hard time buying that the MotoGP bikes are retuned to meet that asinine noise restriction when they run there...
Gigag04 is offline
post #7 of 7 (permalink) Old 03-03-2013, 04:47 AM
suggett48116's Avatar
Bike: 2006 R6
some say the intake sound on the R6 is loud enough to exceed the 92db. I read a thread here (R6 Forum) about people upshifting a gear just so they don't exceed the limit when passing the sound gauge.
suggett48116 is offline
WTT : Bazzaz "Pull" QuickShift sensor with "Push" QuickShift sensor abhijitz Bike Parts For Sale 5 05-16-2013 04:20 AM
does the 06 r6 have a bank angle sensor or tip over sensor? cbrkp General Discussions 2 10-01-2012 05:49 PM
WTT your Bazzaz Standard Shift QS sensor for my GP shift Sensor Gunnar971 Bike Parts For Sale 0 07-11-2012 08:33 AM
Questions about cam position sensor (cylinder identification sensor) Tickers Garage / Mechanical Help 0 06-28-2011 10:54 AM
WTB: 99-02 R6 Neutral Sensor, Rear Engine Single Wire Sensor (WTB) int76 Bike Parts For Sale 0 03-29-2009 09:53 PM
