Clutch stays semi-engaged in gear - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 11-21-2012, 01:29 PM Thread Starter
Hey guys I'm trying to fix up my buddies 2012 r6 here and am just about done... then I ran in to a road block. When the bike is in gear and I pull the clutch lever all the way in...it acts like it's still partially in gear. You have to really fight the bike to roll it. In neutral the bike rolls as normal without any resistance.
I put it on stands to check it out and when you turn the bike on and drop it in gear the chain/tire/etc starts moving rather quickly when the clutch is pulled all of the way in to the point where you cant put your foot on it to stop it - you have to use the brake. After you stop it from moving it wont take off again until you let the clutch out. Why wont my clutch disengage?
Yes. I have adjusted the clutch cable in many different ways from the lever and down at the adjustment nuts. Yes the arm is lined up with the line and the dot on the oil cover. Is it possible the cable was damaged in a crash?
Trailerboy531 is offline
post #2 of 4 (permalink) Old 11-21-2012, 04:07 PM
"The Dude abides .. "
MELK-MAN's Avatar
Re: Clutch stays semi-engaged in gear
new clutch plates take a few miles of use to wear in to the point the clutch won't drag slightly, or make the rear wheel spin on the stand, when in gear with clutch lever pulled in.
Is the cable damaged?? take a look.. it's totally exposed to view..
MELK-MAN is offline
post #3 of 4 (permalink) Old 11-21-2012, 05:28 PM
Lifetime Premium
LiveFastDieLast's Avatar
Bike: 09 R6
Agreed...
Cars do the same things if you dont replace with OEM parts..
Did you use a stock clutch?
Keep your Knees in the Breeze
"Only two types of Whiskey I don't like, Dick and Throttle" - A Wise Man.
LiveFastDieLast is offline
post #4 of 4 (permalink) Old 11-21-2012, 05:32 PM Thread Starter
I used the one that was on the bike when I crashed. It was undamaged. I've ridden it since then and it was that the clutch plates were sticking. Thanks for your help guys!!!
Bike "walks" in 1st gear with clutch pulled in (replace clutch) DTcrew4 Garage / Mechanical Help 151 04-19-2012 10:12 AM
Hilary Duff gets engaged!! ****NSFW**** insertcoins Off Topic Talk 16 02-26-2010 09:49 PM
I'm engaged! hunter1671 Off Topic Talk 65 11-26-2009 06:21 AM
fully or semi synthetic?? clutch slip?? kevyz80 General Discussions 2 09-17-2007 09:31 PM
Disengaged and re-engaged, and odd dying 2006R61999M3 General Discussions 2 03-10-2007 01:58 PM
