Brembo RCS19 Install Help - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 95 (permalink) Old 11-25-2012, 06:23 PM Thread Starter
image0r's Avatar
Bike: 2009 Yamaha R1
Originally Posted by shad0ws View Post
If you are stuck on using the Fren Tubo bolt then I would recommend cutting some off the end of the threaded side. But now after looking at it, the thread patterns don't look the same. I hope you didn't fudge the threads inside the brembo...
I've been careful and haven't over tightened anything down for this very reason
Sent from my iPhone using
image0r is offline
post #12 of 95 (permalink) Old 11-25-2012, 06:33 PM
I have 2 belly buttons.
shad0ws's Avatar
Bike: '09 R6
Re: Brembo RCS19 Install Help
If you can hold both the bolts together and mesh the threads and they look pretty uniform, then you should be good. I personally don't see anything wrong with double stacking the crush washers. They should seal off on each other just fine.
shad0ws is offline
post #13 of 95 (permalink) Old 11-25-2012, 06:53 PM
track fiend
easbaysav's Avatar
Bike: 14 D675R, 15 ST3RX, 15 R1
If the Fren Tubo banjo bolt went to your OEM M/C, don't try to use it. The thread pitches are different as I mentioned already.
The reason the Brembo banjo bolt seems too long is because the banjo fittings on your Fren Tubos are narrower than OEM/other makes. Your options are to source a proper fitting banjo bolt with 1.0 thread pitch, file/cut/shave off a few threads on the Brembo banjo bolt, or double up on the crush washers.
I'm running the last option on my R6 now, but not sure how long I'm going to keep it like that. Might shave some threads next brake fluid change... or leave it if it's still holding up.
easbaysav is offline
post #14 of 95 (permalink) Old 11-25-2012, 07:17 PM Thread Starter
image0r's Avatar
I did the washer method; I'm not sure if this looks right. Perhaps Im just paranoid?
image0r is offline
post #15 of 95 (permalink) Old 11-25-2012, 07:18 PM Thread Starter
image0r's Avatar
Thanks for the advice. I stopped immediately when I found out the fren banjo bolt was not going to take!
image0r is offline
post #16 of 95 (permalink) Old 11-25-2012, 07:22 PM
track fiend
easbaysav's Avatar
I thought the same thing when I did it. Bled the brakes and had no leaks so I took her for a spin and still no leaks.
No problem, would really suck if you were to cross thread your new M/C.
post #17 of 95 (permalink) Old 11-25-2012, 07:31 PM
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 15 Ninja300
I had the same issue with mine. You might want to change your setup based on this post in my thread...
Originally Posted by MELK-MAN View Post
YES, it does.. however you will need to put an extra crush washer nearest to the "real" bembo master cylinder as the OEM bolt is longer than the "real" one. Do NOT make the mistake of putting the extra crush washer on 1st (at the bolt head) as that will offset the holes for the line fitting and the bolt and the fluid will not flow back into the master cylinder fast enough, dragging the pads, and warping rotors. Yes.. been there. Done that.
I ended up just getting the correct sized bolt for it from Galfer.
HIS OWN 6 is offline
post #18 of 95 (permalink) Old 11-25-2012, 08:05 PM
Yoga Pants Connoisseur
babymilo36's Avatar
Bike: Kobe XI
Sherman,
Look at the length of the Fren Turbo bolt vs the Brembo one supplied in the kit. It's too long.
Brad (Riders Discount) PM'd me back and said he will get with the Tech's first thing in the morning.
I told you that, dummy!
CMRA #620
Wreck It Pandas #68
babymilo36 is offline
post #19 of 95 (permalink) Old 11-25-2012, 08:16 PM
track fiend
easbaysav's Avatar
Interesting, I read to double up under the banjos, not in between. I'll have to see if there's any issues with my setup over time.
post #20 of 95 (permalink) Old 11-25-2012, 08:21 PM
I'd Flip it :popcorn:
tfs32's Avatar
Bike: 07 R6 09 R1 KTM EXC330
I had to order the brembo banjo for my fren Tubos I have the 19x18 mc. it's a $7 part.
Thanks to my 2015 Sponsors
Pirelli - Good Grip Racing - Velocity Calibrations - Imo's Pizza
MCRA Expert GT #32
Follow me at
tfs32 is offline
Brembo RCS19 Light Switch mchale2020 Garage / Mechanical Help 2 05-01-2012 05:37 PM
WTB Brembo 19x20 BIERAAP Bikes + Parts + Gear Wanted 1 12-09-2011 05:18 AM
Brembo RCS Question Moto Psycho Appearance and Exterior Mods 4 09-06-2010 07:14 AM
R6 & R1 Owners who Have Brembo RCS19 HardRacing. General Discussions 0 03-23-2010 02:43 PM
Brembo M4 Monoblock Calipers/Brembo RCS19 master cylinder rob1960 Product Reviews 47 11-19-2009 09:41 AM
