Why does the motorcycles rear wheel spins while revving the engin? - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 14 (permalink) Old 11-30-2012, 09:36 PM
Got street appeal?
shnormo's Avatar
Bike: '04 and '07 R6
Images: 1
Send a message via AIM to shnormo
Re: Why does the motorcycles rear wheel spins while revving the engin?
Technical explanation: Cold bike, cold oil, cold parts.
Metal is cold therefore the clearances between clutch and transmission components are tight hence will have the tendency to let some energy be transferred to the transmission gears. Cold oil is more viscus and with the tighter tolerances enough energy is transferred to the output shaft therefore turning wheel when cold.
Bike heats up everything expands and the oil flows, the rear wheel will stop spinning with the engine running and in neutral
shnormo is offline
post #12 of 14 (permalink) Old 11-30-2012, 09:37 PM
Yeah Science!
wutsup's Avatar
Bike: gixxer chrome edition
It's normal, don't worry about it. It happenes because the engine oil is cold. I'm not sure why it does it, but it has something to do with the wet clutch.
Chris
06 GSXR 750
08 Track R6 RIP
wutsup is offline
post #13 of 14 (permalink) Old 11-30-2012, 10:43 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
This is the answer. That cold parts bit is way off base, but the cold, viscous oil is the correct answer.
/thread
pickpocket293 is offline
post #14 of 14 (permalink) Old 12-01-2012, 07:33 AM
My Power band is blue
NorthShoreR6S's Avatar
Bike: 2009 sold,2008 R6 pink
yes...normal. Worst case scenario you just change the blinker fluid and you're all set. Like $5.
I need a new sig, Can someone make me one please?
NorthShoreR6S is offline
T-rex rear stand, can't take off rear wheel? racerviii General Discussions 12 07-25-2012 06:57 AM
Crankshaft spins backward, but not forward? ClemsonR6 Garage / Mechanical Help 16 03-22-2011 09:17 AM
Front sprocket spins when in neutral jibbonacci Garage / Mechanical Help 9 04-19-2010 04:08 PM
on stands(in N) and still rear spins? csmiller18 Garage / Mechanical Help 11 02-10-2009 05:55 PM
Over-revving?... Kazor Exhaust and fuel delivery 3 07-02-2008 09:35 AM
