Oil Pan Write up? - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 20 (permalink) Old 12-06-2012, 01:15 AM Thread Starter
Bike: 2007 YZF-R6
Re: Oil Pan Write up?
Originally Posted by verybigtiter6 View Post
how is the strainer PITA?
I'd like to know this as well. So I see I have to remove the headers. Do I need to replace the header gaskets as it says in the service manual or do I not have to worry about them. And what exact kind of sealant do I need to use for the oil pan gasket? I see several types of yamabond on their website.
friedshrimp is offline
post #12 of 20 (permalink) Old 12-06-2012, 05:22 AM
Jdawson2012's Avatar
Bike: 2007 R6 Candy Red
It can move and fall out of place, so when you go to put the pan back in it doesn't fit right. And idk about the header gaskets. Maybe your supposed to... but I didn't and no problems from me. And I just went and used good ole Permatex RTV
Jdawson2012 is offline
post #13 of 20 (permalink) Old 12-06-2012, 07:09 AM
Got street appeal?
shnormo's Avatar
Bike: '04 and '07 R6
Images: 1
Send a message via AIM to shnormo
I reuse the old gasket. I don't make a new one using the above copper sealant. I just use a light dab on one side to make sure they sit in the head and don't fall out when you try putting the header back on.
Yamabond semi drying gasket will do you fine for the oil pan
shnormo is offline
post #14 of 20 (permalink) Old 12-06-2012, 08:38 AM
cheefar6's Avatar
Bike: 2008 YZF-R6 x2
i would not re-use header gaskets, they compress after use, and conform to the position the header got tightened down, once taken off they will not work perfect again.
yamaha for some reason charges a lot of them, and my dealers never have them in stock.
i would go to suzuki they sell singles for ~2$
the reason i would not skimp on that is because youll have an air leak at the connection and the bike will sound weird/ not run correctly.
cheefar6 is offline
post #15 of 20 (permalink) Old 12-06-2012, 09:03 AM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
Yeah, don't skimp on the gaskets for the oil pan. However, I've removed a lot of headers and I've yet to get new header gaskets.
pickpocket293 is offline
post #16 of 20 (permalink) Old 12-06-2012, 09:13 AM
My94GT's Avatar
sig by milko
my build thread-
My94GT is offline
post #17 of 20 (permalink) Old 12-06-2012, 10:45 AM Thread Starter
Bike: 2007 YZF-R6
Well I am definitely going to replace the oil pan gasket. Already got a new one on order with the dealer, supposed to come in tomorrow. Do I need to use an RTV gasket maker though in addition to the new gasket? Or do I not need to use any sealant with the oil pan gasket. Kind of confused now.
post #18 of 20 (permalink) Old 12-06-2012, 04:40 PM
Got street appeal?
shnormo's Avatar
Images: 1
There is a paper gasket that you can buy. P/N 2C0-13414-01-00. It is important that you use this gasket to control oil splash and keep oil from clinging to the crank.
It is not necessary to put any kind of coating on this gasket but some people put some of that gasket maker on both sides of the paper gasket to insure no leaks
shnormo is offline
post #19 of 20 (permalink) Old 12-07-2012, 06:19 AM
cheefar6's Avatar
u more then likely have a slight leak then, i reused mine twice before i noticed a difference in sound, with new ones it for sure made a difference.
cheefar6 is offline
post #20 of 20 (permalink) Old 12-07-2012, 06:20 AM
iRun
It's a track bike... I don't really give a shit about the sound.
HID write up Jr1321 Garage / Mechanical Help 1 08-12-2011 03:30 PM
R1 vs 911 GT3 Cool write up MotoMillion General Discussions 4 05-16-2011 03:36 PM
Adding a Gps to a 99-02 (write up) scrnnmssuck Appearance and Exterior Mods 0 07-24-2010 03:31 AM
'00 Oil Change Write Up (If you don't already know.) Paul79UF How To's... 3 05-02-2007 06:06 PM
