Hoisting 08 R6 using garage rafters - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 29 (permalink) Old 12-09-2012, 01:51 PM
( . Y . )
MorrowDeath's Avatar
Bike: OH FOUR R599
Re: Hoisting 08 R6 using garage rafters
waiting.........
"If you put your mind to it, you can accomplish anything"..... Marty McFly
MorrowDeath is offline
post #12 of 29 (permalink) Old 12-09-2012, 01:51 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
GOOGLE, MOTHERFCKER! DO YOU USE IT?!
d
pickpocket293 is offline
post #13 of 29 (permalink) Old 12-09-2012, 01:53 PM
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
I know where it is, I just thought seeing how you posted it......
Tdub is offline
post #14 of 29 (permalink) Old 12-09-2012, 01:57 PM
iRun
Not you, the OP.
I know I've put it up here somewhere, but I don't think I put it in its own thread, and the step-by-step instructions were a little lackluster.
EDIT: actually, the link is in post 2 of this thread. *facepalm*
post #15 of 29 (permalink) Old 12-09-2012, 02:02 PM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Harry,
Try something like this:
A better setup is two ladders with double 2x4's across and straps down to the rearsets. But you need man power or a stand to left it, then set it ONTO the strap hooks. This is critical. Cause unless you've got a bunch of help/muscle, getting it down gets weird.
Otherwise I'm sure someone has pics of when we swapped the suspension between two bikes in one weekend. I'll textg around for pics of that. It was a way nicer setup. LOL
ChiefSmokeDawg is offline
post #16 of 29 (permalink) Old 12-09-2012, 02:17 PM
Tdub's Avatar
Bike: Honda Z50
These work really well...
They are ven running a special now where if you purchase any stand, sprocket set, etc. you get a free subscription to RoadRacing World magazine.
Tdub is offline
post #17 of 29 (permalink) Old 12-09-2012, 03:11 PM
Raven Red!
Mikey Fresh's Avatar
Bike: 2007 R6R Candy Red
who makes those stands in the first pic?? i could relly use those haha
Mikey Fresh is offline
post #18 of 29 (permalink) Old 12-09-2012, 03:19 PM
Eric10301's Avatar
Bike: 08 R6 Track Bike
Pit-Bull obviously.
Eric10301 is offline
post #19 of 29 (permalink) Old 12-09-2012, 03:26 PM
When in doubtThrottle out
mercenary's Avatar
Bike: Always Under Construction
Originally Posted by pickpocket293 View Post
Not you, the OP.
I am dissapoint
That should be in your sig
2009 YZF-R6
2010 Ninja 250
MCRA/CCS#81
Originally Posted by doctorv
I was wrong.
Quote taken 7-16-15 @ 0640CDT
mercenary is offline
post #20 of 29 (permalink) Old 12-10-2012, 01:20 AM Thread Starter
iHak's Avatar
To remove the rear shock I just used two jack-stands on the foot pegs so that the rear wheel is off the ground (and it's even easier if you remove the rear wheel after it's suspended, also). As far as the forks, just get a triple tree stand, or a tall sturdy step ladder and use a ratchet strap like I did here:
p=2698909&postcount=27[/url]
I'd be scared that my ladder would fold with that much weight!
Originally Posted by Eric10301 View Post
If you have all the fairings off you can do it like I did. Buy some soft straps and run them through the frame then connect them to some ratcheting straps.
Yeah that's what I was thinking of doing. My fairings are all off.. I wonder if I could hook up the ratcheting straps to the rafters in my garage... I'm scared it's too much weight. I have no clue.
If you like working on your bikes, a good set of stands is a good investment.
I have a good set of aluminum LP stands (rear stand and a triple tree stand.. rear stand is where the problem lies).
Originally Posted by mgossel View Post
You can buy a set of Craftsman stands at Sears for $20-25. That's what I used when I changed out my rear shock.
Yeah I saw something similar on Amazon. I got a reed bar that fits through the swingarm joint hole, and was thinking about putting a stand on each side of that. But is it safe to lift the bike that way? Will I damage anything, lifting it through that hole?
This is the rod I was talking about, going through the joint where the swing arm joins to..*
Then I could put one of these on each side of the rod:
Originally Posted by ChiefSmokeDawg View Post
Harry,
Thanks Ant! That's a good idea, two ladders with a beam. But, could I just hook the ratcheting cables up to my garage rafters? I think they're about 2X8 pine.. maybe strong enough..
You might actually know the answer to my question earlier. Whatever way I decide to lift the bike, I would like to lift using a steel bar that goes through that hole where the swingarm joins, and hook either a strap to ladders/rafters to either side of the steel bar, or use 2 jack stands, on either side.. would that damage anything inside that joint?
Those look awesome. I would like something that can lift and lower the bike though, rather than having a fixed stand.
I was thinking of setting up a winching system to one of my rafters, but again, not sure how much weight they could bear. Maybe the jack/stands would be the best way..
My poor bike.. *sob*
iHak is offline
Garage Mod Potter General Discussions 31 09-11-2010 06:19 PM
Your Garage YZFR62007 General Discussions 109 05-13-2009 07:02 AM
Garage 317 Rider General Discussions 14 08-24-2008 09:28 AM
The best garage frankieg22x General Discussions 0 07-20-2008 11:07 AM
The Dream Garage YZFR62007 Appearance and Exterior Mods 8 07-23-2007 07:51 PM
