Is your QS hooked right up to the ECU? If so you want to wire the ground wire on the QS to the ground wire of the tip over sensor to help eliminate electrical noise. If the QS is acting up, buy a ferrite choke for it.
thanks guys, i just went ahead and crimped a ring connector and grounded it to the negative terminal of the battery - this is what many others who are running a bauce-flashed ecu and dynojet QS are also doing
You can always ground to the negative battery terminal.
Related Threads
3.1M posts
112.1K members
Since 2003
