So i go into a lowside without sliders so my stator cover got all rashed up to the point where it scuffed the flywheel bolt just a tiny bit. So i decided to replace the bolt while replacing the stator cover. Mind you i didnt have a rearstand, it was just in the kickstand. So i tried loosening it up and everytime i turned it i heard air coming out and the flywheel kept moving with the bolt as i turned. I tried to rotate it a few times then decided to give up because it didnt feel like it was loosening up. I tried to retighten it but it wouldnt tighten like the gears inside where locked up or so ethi g so i check the flywheel to see if there was a gap from loosening it but there was none then i just replaced the stator and filled the bike up with oil. The buke doesnt feel right though like it gets rough when i gas it and it is a lot louder than before. Feels like if i push it hard the engine might get damaged... Anyone go through the same thing or have any tips on what this could be?
Thanks in advace.
Thanks in advace.
