I'm hoping someone can help me out with what my R6 is doing. I'm not even sure what this sound is called, so I can't google any more on ways to fix it. :crying:
Here are some sound clips I took...sorry they're not the best quality.
Do you have the autotune? Could it have changed something to make it weird. I'd try unplugging the PCV anyway just to eliminate it as a possible cause.
I'd still unplug it and hook the stock connectors back up just to see. I remember reading before someone was having problems and it was a bad PCV even with a zero map.
Might want to check the coils in diag mode to see if they are within spec.
I think like the other guys. start simple. remove the pcv. eliminate as much stuff as possible.
I take it there are no trouble codes showing on the dash?
Related Threads
3.1M posts
112.1K members
Since 2003
