the rotors are stainless steel but they still get a little bit of rust. it's normal. especially if you keep it outside even under a cover.
make sure you are using a cover that has vents. covers can trap moisture under them and condensation will form causing stuff to rust and corrode.
lol may be you have cheap brake pads? o_0...buy some EBC Double-H Sintered Brake Pads. You will see a difference unless you want to change out those calipers and rotors too.
Related Threads
3.1M posts
112.1K members
Since 2003
