2007 r6 RPM Hanging - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 6 (permalink) Old 01-09-2017, 12:58 PM Thread Starter
2007 r6 RPM Hanging
Hi all, new member here. I have searched and can't seem to find a thread that addresses my issue where the bike is fuel injected. Most of the rpm hanging threads I have found are on carbed bikes. There was one by Wanted that was started but I never saw the results of the solved issue on there. Any help would be appreciated, so here it goes.
I have a 2007 r6, 33k miles, had misfires and was running like crap and was dying from idle sometimes. Changed the plugs, runs alot better but still has misfire on cylinder 3 because right after changing the plugs I cranked for 10 seconds and all header pipes were hot except for #3. Haven't checked it again since but I can hear it missing when it's idling from a cold start, but gets a lot better as the bike warms up and after a ride it seems to idle perfectly. But when it cools down again and I crank it it will idle with a misfire again. Idk if this is related to my issue or not but I figured it could be so I wanted to explain that first. Now on to the rpm hanging.
I let it run up to about 140 degrees the other day and started giving it a constant rev to about 2k rpms. I will slowly twist the throttle until it finally starts to rev some, and then keep the throttle still. It will rev a little, then more, then more, and I'll back off three throttle and it will hesitantly bring the revs down to idle again. It has done this for a while when it was misfiring too so it peaked my curiosity and I did it a few more times. Then, all of a sudden it went from 2k rpms to 6k! And I back off the throttle and it stayed there at 6k for like 4 or 5 seconds! Then finally came down to idle again. It did this again right after that so I shut it off (wasn't gonna ride it like that). I went and got some seafoam since I figured my injectors needed cleaning anyway and that might be the number 3 misfire issue. Poured in some seafoam and let it idle for 20 minutes or so. I tried to make it do what it had done the day before by jumping to 6k rpms after letting the seafoam get into the system but it wouldn't do it. I rode it for a while and it acted fine but it does seam like the rpms hang a little. For instance when I quick shift, and pull in on the clutch, it revs a little as if I didn't let off the gas and then when I let the clutch back out it will jump a little from being revved. So they aren't going down as soon as I let off three throttle to shift like they used to. I was thinking throttle position sensor but I have only worked on carbed bikes before. I've worked on cars plenty too but not drive by wire yet like my r6 is so I'm just wondering if anyone has any advice on what to check or do next as I don't want to start throwing parts and money at it if possible (already have more money in it than I figured I would). Sorry for being long winded, i just know its difficult to assess problems without being there to see or feel it so i tried to be as detailed as possible. Thanks in advance guys!
carp_5 is offline
post #2 of 6 (permalink) Old 01-11-2017, 12:08 AM Thread Starter
Any help guys?
carp_5 is offline
post #3 of 6 (permalink) Old 01-11-2017, 07:10 AM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Re: 2007 r6 RPM Hanging
33K do you know if valves were adjusted at all? or the throttle bodies sync'd? also check all the vacuum lines and check for any cracks etc, that could cause the idle to hang.
tdoss1980 is online now
post #4 of 6 (permalink) Old 01-12-2017, 07:47 PM Thread Starter
The valves were done by the dealership by the last owner (my buddy) not too long ago, not sure exactly what mileage though. He has only had it since 15k miles so I'm assuming it was in the 20's that he had it done. I was wondering about vacuum leak too but it's very intermittent. I changed the plugs not long ago but I know I put everything on tight and I would think if there was a leak it would do it often, is that not correct? I haven't sync'd throttle bodies but will search on how to do that. Thanks so much for the response. I might need to take everything back and and check my hoses too since it started a little bit after changing the plugs where I had to remove some stuff. Thanks!
carp_5 is offline
post #5 of 6 (permalink) Old 01-13-2017, 07:32 AM
nova r6
tdoss1980's Avatar
Yea retrace your steps and check over everything thoroughly also check for dry rot in the vaccum lines themselves, Im sure you will find the issue
March 2014 Bike of the month
http://www.r6-forum.com/forums/showthread.php?t=294417
www.fairfaxcycles.com
post #6 of 6 (permalink) Old 01-13-2017, 08:26 AM Thread Starter
Awesome, thanks! Will post what I find if anything
carp_5 is offline
2007 R6 RPM gauge not acting strange 97audia4 Garage / Mechanical Help 5 05-01-2016 07:27 PM
2007 R6s hesitating at high RPM Motodeficient Garage / Mechanical Help 10 06-08-2014 05:31 AM
RPM wire on 2007 R6 zigmunds Garage / Mechanical Help 2 08-12-2009 06:06 PM
What RPM does EXUP valve open at? 2006 2007 Ara Tidwell Exhaust and fuel delivery 2 03-19-2008 12:59 AM
