Wheel is flipped. The open side of the spokes is supposed to be on the trailing side of rotation direction. The photo below is the left side of the wheel. It rotates in the CCW direction.
there is no question it's backward even if he doesn't reply back. seen it posted dozens of times over the years on forums with an R6.
brake calipers are hard to get back on. tell tale sign #1.
Ah thank you I appreciate it I asked some people when I was putting it on if it was one direction only and they said it wouldn't matter! Thank you again
FYI... the wheel has a direction arrow cast right into the spoke. I would check the tire was properly mounted if the same idiots gave
you that advice. :wink:
Related Threads
3.1M posts
112.1K members
Since 2003
