Okay, it was laid over on the right side and where the bottom 2 bolts go the actual case (NOT COVER) where the bolts go into is cracked and I've tried to put Gasket Maker and even jb wield and I'm not having any luck. ANY IDEA'S ON HOW TO FIX OR AT LEAST STOP? THANK-YOU FOR YOUR TIME. the pic shows only 1 broken but there are two .
Okay thank you. But do I apply and then put the cover back on? Or do I apply wait until it hardens then put the cover back on? Do I put the bolt back in while it's wet or wait until it's dry?
devcon may be more oil proof. but we use both at work and they both seem to work the same. but we are only filling in spots of molds that cannot be welded due to space limitations etc. it's not structural at all. just fixing imperfections, scratches and dents etc.
Related Threads
3.1M posts
112.1K members
Since 2003
