Hello I have a 2007 with 18k on the clock. Randomly, last week the speedometer stopped working. It indicates a speed, but it's as if the indicated speed is based off which gear I'm In. The odometer is tracking miles based off whatever gear I'm in, so it's not accurate either. For example, in 6th gear it says I'm doing 33 mph. From what I've researched, I need to investigate the speed sensor, but I'm not aware if there is anything else I should check.
Any suggestions or help is appreciated greatly. Thanks
