99 R6 Spark Plugs/coils/wires Question (and first start checklist) - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 28 (permalink) Old 05-11-2017, 11:32 AM Thread Starter
NitrusReigns's Avatar
Bike: 99 R6 (project)
So, I've searched around and I'm not sure I've found the answer to my question, so I'm going to ask and you all can tell me an ideot if you feel you need to.
We've got a '99 R6 that we've modified pretty heavily and are now very close to trying to get started. However, we are not at all certain that we know what's going on with the spark plug coils and the wiring for them. Here's what we do know (or think we know):
  • cylinders go from 1-4 from stator side to clutch side
  • cylinder 1 gets orange and orange wires
  • cylinder 2 gets orange and black wires
  • cylinder 3 gets grey and grey wires
  • cylinder 4 gets grey and black wires
Can anyone either confirm that this is correct or tell me where I'm wrong? The above info should allow me to get the coils to the right locations so that the spark plugs actually fire at the correct time in the cycle, right?
Here's what we think we have ready to go:
  • kickstand switch is bypassed (it's going to be a track bike)
  • ignition switch, stop/run switch, and starter switch appear to be functioning properly
Additionally, here's what we've done in prep to make sure things work out well:
  • plugs are all new and gapped properly
  • coils all have proper primary and secondary resistances
  • carbs are clean and are getting fuel
  • engine turns over by hand nicely
  • oil pump is primed and oil is topped off
  • bike is in neutral
What are we forgetting before we try to fire it up?
NitrusReigns is offline
post #2 of 28 (permalink) Old 05-11-2017, 11:44 AM
Flyers28's Avatar
Bike: 07 Candy Red R6
Re: 99 R6 Spark Plugs/coils/wires Question (and first start checklist)
I can only confirm your wiring to the coils is correct.
Flyers28 is offline
post #3 of 28 (permalink) Old 05-11-2017, 01:23 PM Thread Starter
Thanks for that confirmation! That was one of the things I was MOST concerned with for sure!
Anyone else - any feedback and thoughts would be appreciated!
post #4 of 28 (permalink) Old 05-12-2017, 02:41 AM Thread Starter
Well, we tried to start it and it turned over great with the starter, but didn't fire.
We confirmed again that it's getting fuel and I can't imagine that it's not getting air, so I imagine it's not sparking.
We will be attempting to check spark today, but since it shouldn't be a problem with the plugs or cool, what's the next most likely culprit? Reg/rec?
What else should we be checking right away?
post #5 of 28 (permalink) Old 05-12-2017, 08:47 AM Thread Starter
It seems like our issue is probably spark-related, but I don't know what would be the specific issue or what to troubleshoot first.
Here's what we've checked or prepared already:
  • engine turns over without any trouble whatsoever
  • neutral and clutch switches are wired properly (not sure how to test whether they are actually working though...)
I just need some guidance from some of the experts around here on what to do next to try to get it running (this is my first full rebuild project).
Thanks in advance for the help!
post #6 of 28 (permalink) Old 05-13-2017, 11:22 AM Thread Starter
I just confirmed that I'm not getting any spark.
Not sure what I should start testing to find the problem.
Any suggestions?
post #7 of 28 (permalink) Old 05-15-2017, 04:35 AM Thread Starter
Trying again to get some help with this - there is power at the coils, but there is no spark when I crank the engine over. I assume that for one reason or another the ECU isn't telling the coils to fire, but what I'm not sure of is where to start in trying to figure out WHY that would be happening. Any thoughts?
post #8 of 28 (permalink) Old 05-16-2017, 04:58 AM
Flyers28's Avatar
Run through the troubleshooting steps in the service manual, starts on 8-11. That is where I would start. That at least provides you a systematic approach which might present the problem along the way, or at least narrow the possibilities down.
Flyers28 is offline
post #9 of 28 (permalink) Old 05-18-2017, 10:51 AM Thread Starter
I've tried to follow this as much as I can, but since I don't have the "pocket tester" that the manual refers to nor do I know what it does to be able to replicate it with my multimeter. I've narrowed as many possibilities as I know how, but I don't know how to "check switch continuity" with my multimeter - not sure what they mean by that.
Can someone shed light on that?
post #10 of 28 (permalink) Old 05-18-2017, 11:09 AM
Flyers28's Avatar
I don't know why yamaha tries to make everything so special in their service manuals, but a quality multimeter will do it all. What brand multimeter do you have? It is usually a dial on the multimeter (usually paired up with other symbols like ohms for resistance) but sometimes its a symbol that usually represents sound coming from a speaker. When a circuit is a closed loop it makes an audible tone, if no tone you have an open circuit.
The picture shows a multimeter set to check continuity. Sometimes you will also have to hit mode till you see the corresponding symbol (see below where it says "detector") on the screen.
Flyers28 is offline
Having trouble taking apart my bike to change coils and spark plugs... cadillacp General Discussions 10 06-19-2015 04:12 AM
question about wires and plugs on the bike R6Pnoy General Discussions 5 08-08-2013 12:28 PM
Price for spark plugs or coils psyduckiee Garage / Mechanical Help 0 05-20-2009 05:15 PM
bike wont start help! (not batt. or spark plugs) inFEARandFAITH Garage / Mechanical Help 2 08-25-2008 05:20 PM
Changing Spark Plugs/Checking Ignition Coils Arbee How To's... 0 02-05-2007 11:34 PM
