2005 r6 fuel pump wont prime - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 28 (permalink) Old 05-17-2017, 11:57 AM Thread Starter
Garage
Hey guys, this is my first post on here although ive been on and reading threads for a while. I recently bought my r6 NOT RUNNING. Someone had attempted to steal the bike and mashed up the ignition bad [i have the title from previous owner and now in my name, i didnt buy a stolen bike!]. I have replaced that, but when i went to fire it up it would crank and not fire. I didnt heard the pump kick on, so i did some investigating [on these forums]. I found a lot of people had issues with the SCCR [Starting Circuit Cut-Off Relay] which would cause issues with their pump not kicking on. I bypassed the relay, and got the pump to kick on but it runs continuously. The bike starts and runs, but i have a code now due to voltage issues and i am afraid i will fry my ecu if i leave it wired up the way i have it.
Now heres the kicker. I just got a replacement relay, put my wiring back the way it was, and still same issue. Ignition on, in neutral, kill switch in run position, and no pump priming/turning on. Any ideas??
PrepareForTakeOff is offline
post #2 of 28 (permalink) Old 05-17-2017, 12:52 PM Thread Starter
Garage
Re: 2005 r6 fuel pump wont prime
I also forgot to mention i have tested the wire from the fuel pump to the relay [red w/blue stripe] for continuity and it is good. I have a wiring diagram i was looking vut the only thing i can locate from the ecu to the fuel pump is that relay. Could it possibly be a bad ground?
post #3 of 28 (permalink) Old 05-17-2017, 12:54 PM
Flyers28's Avatar
Bike: 07 Candy Red R6
Hmm, lets start with the error code. What error code and when/how are you getting error code?
What have you checked other than SCCR? Did you check Fuel Pump resistance? Wiring/connectors?
Could very likely be an issue with your wiring/connections, I would spend time here to make sure.
Someone will have to correct me here if I am wrong but I think the fuel pump shuts off when a certain pressure is sensed? Does fuel leak out of injectors or anywhere else for that matter when it actually primes?
I'm just throwing things out there to get your thread rolling. But the more info we can get the more likely someone has a solution.
Flyers28 is offline
post #4 of 28 (permalink) Old 05-17-2017, 01:11 PM Thread Starter
Garage
The error code is 43. I get it only when i have the jumper wire connected to get my fuel pump to kick on. [Bypassing the relay off a switched power wire] i have not checked fuel pump resistance, i am assuming it is good solely based on the fact i got it to kick on and the bike to start. The connectors look in good shape, no corrosion and all pins are in tact. I also am under the impression the fuel pump shuts off after priming and reaching a certain psi [i dont have the specs in front of me]. It could be possible its not reaching its pressure because theres a leaking injector(s). That is something i havent considered. The bike sat for roughly 2 years before i got it to start after buying it so it is possible it has some injector issues going on as well.
post #5 of 28 (permalink) Old 05-17-2017, 01:27 PM
Flyers28's Avatar
Oh ok, good so error code is a non issue then.
Another thing I would check, more so to limit possible faults, is to pull the connector (R/L, B) to the fuel pump and check the voltage when bike is switched on. If your not getting around 12V and you can confirm the wiring from the relay to the pump is good then you know your issue is the power to the relay.
Flyers28 is offline
post #6 of 28 (permalink) Old 05-17-2017, 01:31 PM Thread Starter
Garage
So if the relay isnt getting power it looks like [based on the wiring schematics] that the problem would be with the ecu if im not mistaken? I will check this asap
post #7 of 28 (permalink) Old 05-17-2017, 01:53 PM
Flyers28's Avatar
Disregard what I said about checking the voltage at the pump because if your relay isn't switching then your obviously not getting voltage, duh. You got the pump to run so checking this voltage even jumped is useless, haha.
Could be or hopefully just a bad connection or wire. You can test the continuity from the SCCR to the ECU ( light green wire). I can't imagine it being a bad ECU, I would think you would have other issues. And the fact that you got the bike to run also helps to rule out some other issues as well. Since it runs but only jumped we can rule out items such as the engine stop switch and everything downstream. Which means the R/B wire which feeds power to the positive side of the inductor in the SCCR relay gets power, therefore if there is an issue it is the negative side of the inductor or the Light green wire mentioned previously. (Thinking out loud here, haha).
Flyers28 is offline
post #8 of 28 (permalink) Old 05-17-2017, 02:20 PM Thread Starter
Garage
Lol well i appreciate all of your knowledge and help! I am not much for troubleshooting electrical, but i do what i can with a diagram. Everything is working as it should when i have the R/L and the R/B wires tied together that go into that relay. Ive ridden the bike 200 miles with no issues [except a bad coil causing a cylinder to shut down] but that engine code worries me because i feel like im backfeeding power through the ecu and dont want to fry it. I want to fix it and fix it right, hence why im here asking for any help i can get!
So far with those wires jumpered i have a constantly running [not priming] fuel pump and the bike will start. With the brand new relay installed and all wiring back to factory i have no fuel pump at all.
post #9 of 28 (permalink) Old 05-17-2017, 02:54 PM Thread Starter
Garage
I will test that light green wire for continuity tonight when i get home from work.
post #10 of 28 (permalink) Old 05-17-2017, 04:32 PM Thread Starter
Garage
I was looking at a parts list on partzilla and noticed there is a fuel pressure sensor on this thing. Im now wondering if its faulty and not telling my ecu to turn the fuel pump on. One of my buddies has an 03 and if im correct i believe both the ecu and that pressure sensor are interchangeable between my 05 and his 03 r6 so this weekend im going to have him come down and swap some things around. Any more input or ideas would be greatly appreciated!
How does your fuel pump prime? Dude3786 General Discussions 4 01-27-2017 06:36 AM
Fuel Pump Wont Prime Need Help GMusilli Exhaust and fuel delivery 9 02-29-2016 04:31 AM
Fuel pump prime problem. HELP please!! fenwickwick Garage / Mechanical Help 1 06-20-2014 10:43 AM
Fuel Pump won't prime when turned on Gurk Garage / Mechanical Help 5 11-20-2013 11:57 AM
06 R6R pump intermittently wont prime... 240witSR Exhaust and fuel delivery 2 07-01-2012 07:26 AM
