Ignition switch problems - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 05-19-2017, 06:34 PM Thread Starter
I'm running a 2007 R6S that I bought going on a month ago. About two weeks ago I was out for a ride it just cut out and when I tried to restart it I wasn't getting anything from the engine start button. So for the last two week I have been trying to figure out how to fix this. If I cross the positive wire with the starter wire it will start and run til I hit the kill switch but will not start again by just the push of the bottom. I have replaced the starter relay and that did nothing for it. So last night I was checking the wires under the air box I turned the key to the on position everything lights up on the dash but when I turned the key to the off position and pulled the key out everything stayed on until I unhooked the battery. So my question is could both issues be related? Should I replace the ignition switch? Does anyone have any other ideas? Thanks for taking the time to read this any help would be greatly appreciated!
TangoEcho is offline
How to bypass kickstand switch, clutch switch, and keyless ignition cleanly! FSTASFCK How To's... 19 03-21-2017 11:08 PM
ignition switch problems Dr.r6 General Discussions 2 08-28-2012 09:52 AM
replacing ignition switch with toggle switch racemx904 How To's... 1 09-30-2008 02:14 PM
ignition switch problems Bitchin_r6 Garage / Mechanical Help 1 04-09-2007 07:09 PM
03 R6 Ignition Switch Mod - Kill Switch Re-wiring Gio How To's... 8 12-28-2006 12:16 PM
