Yea those were the tough ones to dictate based on pictures. The Red/black wire is a constant 12V source, so what I think (and I am speculating here based on what I can see) is they spliced that Red/black wire to the black/blue wire that fed to the sidestand switch originally in order to bypass the switch. The black wire was the ground wire to the sidestand switch harness which is cut and taped because they no longer needed this as they picked up the ground somewhere else.
But like I said it is really hard to tell if a wire is black or say black/blue etc. So I am merely making assumptions, you will have to check the wiring diagram against what you see to confirm or deny my assumption.
The bike keeps dying after a few minutes of riding. And won't restart DEAD BATTERY. bought a new battery. Same thing. Didn't take long AT ALL. I had the wife follow me and we jumped it 5x to get home. (Let it sit connected to charge 5min at a time).
I did notice. After charging it. If I ramp to high rpm is when it kills the battery and bike.
Shouldn't it run without a battery once started? Ordered a new rectifier anyways even if it's not the issue.
Lol...kinda sounds like you need a separate thread, but you almost definitely have an issue in your charging system. Get out the manual and go through the troubleshooting procedures. I'd there's anything you don't understand, feel free to ask (I just had a few learning experiences in that section of the manual myself)
I traced the wire to a ground. It's grounded to the top of the engine. Idk why They would ground the rectifier when it should already be grounded in the harness. And the rectifier connector has been modified tonuse space clips for top left and top right. The white clip is still there attaching the 3 white wires.
If you need that troubleshooting section of the manual or the wiring diagram or whatever, I've recently been through all of it and quickly either shoot you some pdfs of just the sections you need or send you the page numbers
No idea how common it is on these bikes. I'm primarily a Kawasaki guy. However, personally, I wouldn't do anything at al until fully troubleshooting and diagnosing the actual problem. There's no point replacing something if you don't know what's wrong...
I'll attach the whole electrical chapter as well as just the section about the charging system. The end of the whole chapter (end of the manual) has a full system wiring diagram and the beginning of the charging system shows the whole diagram with just the charging system stuff highlighted (not grayed out).
Turns out the black wire that was going to the rectifier was not very well connected. After going through wiring and getting ready to wire the new rectifier up, I tried the old rectifier again for new readings. And it is now reading 13 volt.
That white connector should be the starting circuit cut off relay. Item #9 on the diagram.
Related Threads
3.1M posts
112.1K members
Since 2003
