2007 r6 34k miles, I've had it for about 8 months and haven't had many issues with it, but the other day my HID KIT kept popping the fuse. It was a long time coming to replace them anyway so I bought new ones. Installed them today, put in another 15 amp fuse (even though it called for a 20 amp I didn't have one right then and figured a lighter fuse would be fine. Not sure if it is related or not but I rode a couple miles home from where I was working on the bike. Got home and was parking the bike and turning the steering column back and forth backing the bike up when the fan kicked on because the engine reached 212 degrees, and when the fan came on there was a high pitch whining noise. I stopped for a second and then thought maybe it was normal but I never noticed before because I forgot to put the little cowlings back on that cover the ballast boxes and wiring when I was done with the HID install. So I was deciding if it was normal or not while still backing the bike up and when I turned the handlebars one way or the other the pitch and volume of the whining noise would change, back and forth every time I turned the handlebars. Then suddenly the bike died immediately and I lost all power. Turned the key off and back on and still no power. I had to leave the bike and haven't been able to look at it the rest of the night but I'm assuming I popped an ignition fuse or the ignition went out or ecu went out or something. I tried to explain the best I could so hopefully I explained what happened accurately. Also I haven't been able to diagnose anything so I know my post is a little premature but I didn't know if anyone has experienced anything like this before? I'm hoping it's simple but I'm scared that it's not. Even then, what could be popping all my fuses suddenly? Thanks for the help!
