2000 r6 fuel pump? ...not starting... - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 10 (permalink) Old 09-05-2008, 02:07 PM Thread Starter
Here's the scenario...
Nothing changed...nothing different...
Went for a ride...when I stopped it started to sputter...
gave it some gas...it picked back up again but as soon as it went to idle it sputtered and died...
THAT'S IT!
Long story short...I parked it at a friend's house (in the area) who pulled the tank off (when I wasn't around) and told me it was the fuel pump. Keep in mind this friend is by no means a mechanic...but does have some experience with motorcycles.
So, I called to ask how much a new fuel pump is...thinking it would be under $50.
They told me it was $780!!!!!!!!
They said cuz the pump is in the fuel tank it's much more expensive.
That doesn't seem right to me...but I'm no mechanic...so I've been puting off investigating further until I have a bit of cash saved up...
So, today I pull off the tank thinking I'll try to replace the fuel filter...start small and work up to these BIG things...
Wow, what do you know...
The fuel pump is NOT in the tank...and after I pulled it apart I find the fuel filter is clogged and not a drop of gas is to be found in the line after the filter...
Still not knowing for sure what it could be I take my filter to the parts store...
they sell me a new one...
Like a dumb guy who doesn't know what he's doing...
I blow some air through the old one...
the slightest trickle comes out the other side after i put a lot of pressure on it.
I blow some air through the new one...right through...No problems!
It's like blowing through a big yellow McDonald's straw.
Excited I rush home and rebuild my bike...
Go to fire it up...
NOTHING!
it turns over but it won't catch...
open choke, closed choke, open throttle, closed throttle....
The battery isn't dead but it is getting there I've been trying so much.
I pulled it all apart again to see what the problem is...and there's still no gas passed the fuel filter...
When I saw this is got frustrated and closed the garage and came back into the house.
So, I figure I've been lied to a few times and I was wondering if anything here had anything to say about it...
Why isn't gas getting through the filter?
Where IS the fuel pump.
I'm not a mechanic...but i'm not afaird of pulling things apart (possibly a very bad combination). I have some experience with working on vehicles.
I've consulted the mannual available on this site but it doesn't show location of the fuel pump or even what it looks like.
WHY ISN'T THE GAS GETTING THROUGH!
WHAT HAVE I MISSED?
Thanks in advance,
RJ
RYJAY is offline
post #2 of 10 (permalink) Old 09-05-2008, 02:41 PM Thread Starter
Re: 2000 r6 fuel pump? ...not starting...
Okay...fuel pump was easy enough to find...all i had to do was look...
I got a price of 283$(CDN)...which is still WAY too much...
anyone know where the fuse for the fuel pump is?
RYJAY is offline
post #3 of 10 (permalink) Old 09-05-2008, 02:46 PM
2B R <> 2B
zanatos1914's Avatar
Bike: R6 01 -- Gen 01 Represent
Can you please give the cliff notes on this...
zanatos1914 is offline
post #4 of 10 (permalink) Old 09-05-2008, 03:07 PM Thread Starter
I found the fuel pump simply by following the fuel line...
it is right beside the rear shock, mounted the the frame on the right side of the bike.
I don't hear it 'tick' when i turn the bike on...
but it might be cuz my battery is too low...
and I don't have any equipment to test the pump...
any ideas?
RYJAY is offline
post #5 of 10 (permalink) Old 09-05-2008, 03:12 PM
My R6 has returned!!
varnaR6's Avatar
Bike: 2005 R6, 2007 R1
Fuel pump at Mrcycles :5EB-13907-01-00 is 131 USD.
If you're not getting fuel flow after the filter - then I wouldn't worry about the pump. Did you put your petcock back to the "ON" position when you finished? That's my first guess.
Is there no fuel flow if you leave the petcock on and disconnect the fuel filter from the tank side?
varnaR6 is offline
post #6 of 10 (permalink) Old 09-05-2008, 03:14 PM
varnaR6's Avatar
three reasons your pump won't click:
1. no power (check the leads to the pump are connected)
2. already filled with fuel
3. broken - sorry.
varnaR6 is offline
post #7 of 10 (permalink) Old 09-05-2008, 03:18 PM Thread Starter
ya...i turned it back on...and there is fuel.
but always worth a shot.
problem:
tank-tube-filter-tube-pump-tube...
the odd part is...there is no fuel between the filter and the pump.
RYJAY is offline
post #8 of 10 (permalink) Old 09-05-2008, 03:20 PM Thread Starter
1. also...leads are connected
2. and if it's already got gas in it...isn't that a good thing?
3. dammit...looks like this could be the problem...maybe i'll go buy a mtere to test it before i order...thanks for the part number.
RYJAY is offline
post #9 of 10 (permalink) Old 09-05-2008, 03:48 PM
varnaR6's Avatar
Good that leads are connected - you can test the leads for continuity when switched on to be sure power is there.
Well since your bike shut itself off from lack of fuel, you're probably right to think the pump is dry.
The tube from filter to pump is clean - I mean no cracks of anything? have you disconnected it and have a look through it?
In anycase - once you test for continuity to the pump, if that's successful, disconnect the line from the pump to the carbs - place it in a pan or bucket or something, then turn her on, and flip the engine cut off to "ON" (but don't start it). If your pump is working properly, you'll get fuel flow or whirring/clicking from the pump. If neither, then you know the problem. If you get clicking - problem is before the pump.
varnaR6 is offline
post #10 of 10 (permalink) Old 09-05-2008, 03:54 PM
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: stupid ones and a Prius
I suspect is the pump or the relay. I had to change the pump on my 01 r6 with 19k miles on it....but is cheap and pretty easy.
redisdeadrideblue is offline
Need help with fuel pump relay real quick...DESPERATE! Thanks... buffoni88 Garage / Mechanical Help 9 07-29-2015 04:45 PM
fuel pump question 99 r6 racerX Garage / Mechanical Help 2 08-15-2008 01:56 PM
2000 R6 - Clicking, Whirring and no Starting Popsmear Garage / Mechanical Help 2 08-02-2008 05:20 PM
06-07 R6 fuel tank for sale parapuke Bike Parts For Sale 0 06-24-2007 10:02 PM
FUEL PUMP question! mckean265 General Discussions 0 06-10-2007 09:21 AM
