'06 R6 Throwing Error 1 Code - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 20 (permalink) Old 05-06-2009, 03:02 PM Thread Starter
Bike: '06 R6 - Bone Stock
My 2006 R6 is throwing an error1 code at me on the gauge. Its not turning over but the battery is not dead b/c gauges wake up and the headlight comes on etc. I dont have access to the manual to look it up, anyone know what error1 is all about?
Thanks
2006 R6 - Bone Stock
1970 Pontiac GTO - 454 Chevrolet
2004 Honda Civic - The DD
gi0220 is offline
post #2 of 20 (permalink) Old 05-06-2009, 09:21 PM
Bike: r6s, gsxr 6, f4i
Re: '06 R6 Throwing Error 1 Code
just so you know, the starter takes many more amps than anything on the bike, everything else can work perfect and the battery can be bad,
i dont know what the code means, but find out what exactly it does, does the starter relay click? does the starter make any noise?
hanasanaid is offline
post #3 of 20 (permalink) Old 05-07-2009, 07:23 AM Thread Starter
The relay clicks and the starter makes noise but it doesnt turn over. Im going to call my local shop today to find out what that code means. will post when i find out.
gi0220 is offline
post #4 of 20 (permalink) Old 05-07-2009, 07:33 AM
Bike: Junk
Images: 2
If the code says ER-1 than it is - No signals are received from the ECU.
there is no diag code 1 only error code
strapedR6 is offline
post #5 of 20 (permalink) Old 05-07-2009, 08:47 AM Thread Starter
yep ER_1, also i called a few local shops and no one could give me an answer. the closest i got was one tech telling me that the code is for fuel injection which makes no sense considering my problem.
gi0220 is offline
post #6 of 20 (permalink) Old 05-07-2009, 11:12 AM
Bike: Junk
Images: 2
Take ur seat off an see if the main ECU fuse is blown... Do u have some sort of ecu piggyback? ie: PC3, bazzazz ROM Tune
post #7 of 20 (permalink) Old 05-07-2009, 11:16 AM Thread Starter
no piggybacking items. I'll check the fuses in a few hours when i get home from work. Any chance i just need a new battery? someone else suggested thsi might be the problem.
gi0220 is offline
post #8 of 20 (permalink) Old 05-07-2009, 11:24 AM
Bike: Junk
Images: 2
check battery voltage as well...
post #9 of 20 (permalink) Old 05-07-2009, 11:32 AM Thread Starter
super noob, how do i go about doing that? can i take it down to advance auto or auto zone and have them put it on their reader?
gi0220 is offline
post #10 of 20 (permalink) Old 05-07-2009, 11:42 AM
Bike: Junk
Images: 2
Unless u have ur own volt meter.. in that case it should read 12 volts or more to start... if u dont have one u could bring it to the places stated above... if it reads under 12 volts replace it... i always use oe batteries a little expensive but some motorcycle stores online sell the oe ones for $40
R6 Service Manual Fault Code Table pnrfame Garage / Mechanical Help 23 03-10-2017 08:24 AM
Keep Throwing Code 24 money911 Garage / Mechanical Help 1 10-03-2015 09:18 PM
'06 R6 vs '06 GSX-R600 i've ridden both!!!! Joe2D General Discussions 56 02-19-2010 09:31 PM
05 R6 throwing code 20 acrproject Garage / Mechanical Help 0 03-15-2009 02:20 AM
06 r6 code 18? blu06r6 Garage / Mechanical Help 5 06-09-2008 06:21 AM
