No Throttle Response - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 07-26-2009, 12:36 PM Thread Starter
For a class project we completly disassembled an '06 R6, and have now reassembled it. We had a little issue trying to get it started, but after running the diagnostics discovered that the bank angle sensor was put back in upside down. With that corrected, the bike started right up and responded to throttle input as expected.
After getting up to operating temperature it started to idle rough and stalled. We can start it, but it needs a slight twist of the throttle to keep idling (if you let go the engine dies). It you twist the throttle fully open, it remains close to the idle speed (engine won't speed up). We ran diagnostics again and found no fault codes. We visually verified the throttle plates do open completly, and throttle position sensor via the diagnostics verify's that.
We've got a week to get this resolved. Where do we look now?
andressb is offline
post #2 of 4 (permalink) Old 07-26-2009, 02:05 PM
Dave_Stumph's Avatar
Bike: 06 R6
Re: No Throttle Response
Originally Posted by andressb View Post
For a class project we completly disassembled an '06 R6, and have now reassembled it. We had a little issue trying to get it started, but after running the diagnostics discovered that the bamk angle sensor was put back in upside down. With that corrected, the bike started right up and responded to throttle input as expected.
A bad TPS sensor will give no faults.
In Diag mode
#1 TPS throttle valves Signal 1 suppose to be between 10-24 up to 100
#13 TPS throttle valves signal 2 supose to be between 10-24 when throttle closed up to 100 fully open
#14 TPS for throttle cable pully signal 1 suppose to be between 10-24 up to 100 wide open
#15 TPS for throttle cable pully signal 2 Suppose to be set at 10-24 when throttle closed up to 100 wide open
Now for the Metering test, you can follow me on page 8-97 in the manual!
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv vvvvv
In the manual It just ask to measure maximum resistance between 2k-3k ohms: If you get that on BOTH TPS's Throttle valves and Throttle cable the TPS's should be good. Also I know this may sound stupid but check your fuses. the 7.5amp fuses are the throttle by wire fuses which controls the output from the ECU (i think)
If all checks out....you need to adjust the TPS throttle and cable sensors or possible replace?
Try to keep an open mind as there could be other issues that have the same effect. Spark plugs, coil packs ect!!!!! But because you started your bike and it responded to throttle.....makes me think its not the TPS sensors...fuse mabey?
Keep us informed!!
Dave_Stumph is offline
post #3 of 4 (permalink) Old 07-28-2009, 07:31 PM Thread Starter
I made a mistake, it's an '05 (not an '06).
We checked the TPS, coil packs, plugs and injectors, and everything appeared to be functioning correctly. We could get it to run just off idle, but no response. We started looking at all the vacuum lines and everything was hooked up correctly. Playing with the vacuum line on the fuel pressure regulator we were able to bring up the RPM a little. After that we decided to replace it with one from a crashed bike and we got a huge improvement in response
, but it felt like the cylinders were missing and it wasn't running as smooth as it should. We decided to replace the plugs since they got fouled up with us running it with the excessive fuel pressure and we brought it back to life. We installed al the plastic, cleaned it up, and the instructor took it for a spin.
andressb is offline
post #4 of 4 (permalink) Old 07-29-2009, 05:32 AM
Bike: 06 R6
Good find man!! Glad you got her up and going
Complete guide for learning basic wheelies the right way ADRENALINE RUSH Stunters Corner 20 08-23-2010 12:19 AM
Throttle response 2005 R6 Richard Kuschel General Discussions 0 07-22-2009 06:58 PM
2002 No throttle response...WTF Squid_dremz Garage / Mechanical Help 8 03-12-2009 11:13 AM
Error code 60-No throttle response yanksno1 Garage / Mechanical Help 4 08-04-2007 08:18 PM
throttle response nstyr6 Exhaust and fuel delivery 1 06-23-2007 08:37 PM
